ir 550-600
  • Brucere99
    • Oct 2009
    • 15
    [Error Code] ir 550-600
    Does anyone know what to do with a E100 error code on a Canon iR 550-600? I know it has to do with the laser?
    Thanks,
    Bruce
    • 22999
    Take a look at the laser shutter and it's linkage to the front door. You can also get an E100 with extreme drum fatigue. =^..^=
    • Canuck
      Tech Specialist
      • 1713
      Definitely check out linkage and actuator. You could also clean the beam detect pcb located behind the front fan assembly,ribbon cables between laser assembly and image processor pcb if the mechanical section is OK...
