Ir4570 fax line a cannot work???
    • 16083
    some multi line fax boards do not have a dial tone/or monitoring for Line 2
    • SESHU
      • 163
      Originally posted by teckat
      multi fax board-d1
      for the dual-line fax board, make sure the wire harness from the fax board to the main controller pcb is connected to j1005.
      check that the yellow wiring harness is the correct one. Check that all pins on both sides of the harness are terminated. You must use the harness supplied with this fax option.
      [ATTACH=CONFIG]6363[/ATTACH]
      turn off /check dial tone before sending
      i have dialtone in line a.works fine.fax receive and sending also.
      But no dailtone in line b.
      Line b phone line also iam checking its fine make calls going on and receive also ..after checking line jack ..
      I inserted in to line b. But there in no dail tone... Its silent?????
      That's why iam asking.
      How can i turn on line b signal.
      Iam settings what you said ..all is o.k.
      But there is no display add-on line setiings> .in communication settings>???
      Now what to do...
      How to get dail tone in line b????
        • 16083
        Like i said before/ not all LINE 2's have a dial tone
        All Fax Capable imageRUNNER Models
        Entering a Default Line for Use with a Dual Line Kit.
        Please be aware that this information refers to all imageRUNNER Models with the exception of the imageRUNNER ADVANCE
        When you have an imageRUNNER device with a Dual Line Fax Board, you may need to change the default TX Line priority from Line 1 to Line 2. You may also choose to prohibit transmissions on one of the lines. The selections are for Line 1 and Line 2 "TX Priority" or "TX Prohibit".
        Here is what you will see on the LCD as you make these selections.
          • 16083
          #19
          All Fax Capable imageRUNNER Models Selecting a Line to use when a Dual Line Fax Kit is Installed
          This applies to imageRUNNER devices that support a Dual Line Fax Kit. First, select the "Send Screen" and select "Send settings".
          Now select the "Line Selection" tab
          Here you will see 3 options. They are;
          1) Line 1 is the standard line.
          2) Line 2 is the Additional line.
          3) Auto will select the line as outlined under the "Fax Settings" tab from the "Additional Functions" menu.
            • 16083
            #20
            Originally posted by SESHU
            yes..
            daul line fax board.
            and i have diffrent 2 phone number lines.
            Did u Check those FAX TYPE settings for your Country, that i posted
            • Herrmann
              • Jan 2006
              • 792
              #21
              ok, lets begin with the basics... first at all make sure, that the two analog lines are working correctly by attaching a phone to it. (i have an old headset from a canon fax 170 with me, comes very handy to check lines ) , if that is done and all works fine, connect the fax module with only a 2 wire cable to the jack, to make sure, that no failure in the jack connections is the reason for malfunctioning. What happens?
              If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
              • SESHU
                • 163
                #22
                I CAN,T SEE YOUR IMAGES...
                HOW CANI SET IT???
                AND I SEE OR SERCHING ALSO IN COMMUNICATIONS SETTINGS>The selections are for Line 1 and Line 2 "TX Priority" or "TX Prohibit".????
                THERE IS NO DISPLAY LINE PRIORIIES????
                • SESHU
                  • 163
                  #23
                  i check fax type in my mechine . that is display u.s.a.
                  but i want change to india. cannot changed/edited.
                  so cannot chaged to other country..
                  so i set to you choose set fax>type >1.
                  and you display the sssw settings in my screen displayes
                  fax>type>1
                  fax>sssw>sw30>01000000
                  fax>ncu>dailtone >swo1>00000000. cannot edited these two settings..
                  o.k. fax>ncu>dailtone sw01 items are all edited and it can be chaged also..
                  i set to standard/usa settings.
                  how cani edit /change..
                  fax>ncu>2nd dialtone
                  but 2nd dialtone diasplyes swo1>0000000.............this is also cannot edited.
                  2nd dialtone sw01 item displyes are..
                  001>4000
                  002>3
                  003>25
                  004>5
                  005>25
                  006>0
                  007>5
                  008>5
                  these are edted..
                  so now what to do???
                  how can chage/edited dialtone fax>sssw>sw30 settings 01000000 to 01100000
                  how ????
                    • 16083
                    #24
                      • 16083
                      #25
                      fax>type>1
                      001>4000
                      002>3
                      003>25
                      004>5
                      005>25
                      006>0
                      007>5
                      008>5
                      these are edted..
                      how ????
                      this is how u make settings under Fax Tab
                      #1 SSSW: Service soft switches
                      These switches are for error management, echo countermeasures, communication
                      problem countermeasures, etc., and registrations and settings relating to basic fax functions.
                      #2 MENU: Menu switch settings
                      Registration and settings related to functions required upon installation, such as NL
                      equalizer, output level, etc.
                      #3 NUMERIC Param: Numeric parameter settings
                      Used to enter numeric parameters.
                      #4 NCU: (cannot be adjusted)
                      This item is automatically set according to the settings made in #5 TYPE.
                      #5 TYPE: Country settings
                      When [STANDARD] is set as displayed, #4 NC data are set to conform to Japanese
                      domestic communication standards.
                      #7 PRINTER: Printer function settings
                      Registration and setting of basic service functions for the printer, such as conditions
                      for reducing reception images, etc.
                      #8 CLEAR: Data initialization mode setting
                      Initialises all data to initial settings.
                      #9 TEST: Executes various types of tests.
                      #10 REPORT: Outputs reports.
                      • SESHU
                        • 163
                        #26
                        [ATTACH=CONFIG]6385[/ATTACH]
                        [ATTACH=CONFIG]6387[/ATTACH]
                        [ATTACH=CONFIG]6388[/ATTACH]
                        my lcd screen in send >send settings>line selections???
                        WHERE ??? there is no display line selection button.
                        only in send>SEND SETTINGS>
                        settings ending button direct.
                        THEN HOW CAN I SELECT LINE SELECTION TAB????
                          • 16083
                          #27
                          Did u set up or do u see the option for Dual Line Options-under Communications ????
                          if u do not see
                          Dual Line Options/your Dual Line Fax Modem is not seen as one/
                          where did u get this Fax Modem from ???
                          On the control panel
                          u select>
                          Communications
                          Dual Line Options
                          TX Line Selection
                          In addition to setting these default values, you may also select a line priority in the "Send Settings" screen under the "Send" tab of the LCD.
                          • SESHU
                            • 163
                            #28
                            this is how u make settings under fax tab
                            #1 sssw: Service soft switches
                            these switches are for error management, echo countermeasures, communication
                            #2 menu: Menu switch settings
                            registration and settings related to functions required upon installation, such as nl
                            #3 numeric param: Numeric parameter settings
                            used to enter numeric parameters.
                            #4 ncu: (cannot be adjusted)
                            this item is automatically set according to the settings made in #5 type.
                            #5 type: Country settings
                            when [standard] is set as displayed, #4 nc data are set to conform to japanese
                            #7 printer: Printer function settings
                            registration and setting of basic service functions for the printer, such as conditions
                            #8 clear: Data initialization mode setting
                            initialises all data to initial settings.
                            #9 test: Executes various types of tests.
                            #10 report: Outputs reports.
                            [ATTACH=CONFIG]6391[/ATTACH]
                            [ATTACH=CONFIG]6390[/ATTACH]
                            iam trying somany times..finally i can change.
                            In fax>sssw >then i will go to sw30.. Then i can press sw30 . Its highlighted.
                            I press values then changed.
                            In my lcd screen sw30 values displayes 01000000.
                            Then i changed to my contry asia settings 4.values entered in to 01100000 what you have said.
                            Next fax>type > changed to asia
                            bext fax>ncu>dial tone >swo1>values displayes 00000000.
                            I changed values 00000000 to 01000001.
                            next as well as follows 001 to 008 all values i changed you are showed in the image that values. I can entered.
                            After these settings in send screen>fax> added r buuton.that's hide.
                            I can do system power switch off and on again.
                            After
                            i check line b dail tone. Nothing happend??no dial tone /no response.
                            No diffrent????
                            So can i change the values as well as in fax>ncu>2nd dialtone..???
                            Now what to do????
                            • SESHU
                              • 163
                              #29
                              if u do not see
                              u select>
                              Communications
                              Dual Line Options
                              TX Line Selection
                              [ATTACH=CONFIG]6397[/ATTACH]
                              no.
                              there is no display the line options under communication settings.
                                • 16083
                                #30
                                if u do not see the Dual Line Options
                                then u better check that your Fax Modem cable connection is in correct spot
                                For the Dual-Line Fax Board, make sure the wire harness from the fax board to the Main Controller PCB is connected to J1005.
                                make sure it is not in
                                J1030
                                INSTALL INFO
                                ANOTHER THING/IN SERVICE MODE -under COPIER > DISPLAY > VERSION , if u see
                                PSTN=On Board Fax.
                                u have a single fax
                                imageRUNNER 2270 / 2870 / 3570 / 4570
                                With a single line fax board installed in the machine, it is normal to see the fax version as PSTN=On Board Fax.
                                If a dual line fax board is installed in the machine, a version number will be displayed.
