canon irc4080
  • patrick045
    • Sep 2010
    • 38
    [Misc] canon irc4080
    how do i check the drum life of this machine ?
  • android790
    • Jul 2010
    • 63
    *28*.display-misc for life. Test-txph(10) for test print of all drums for cq flaws
    Yes, I am here to fix your machine. No, your machine went out of warranty 18 years ago.
    • teckat
      • 16083
      To show on Consumables screen/ of control panel
      Yes, in Service Mode level 1.
      To show the Remaining Drum Life Screen, perform the following. COPIER > OPTION > BODY > DLIFE-SW > 1
      or in service mode under>
      COPIER>DISPLAY>MISC
      Y/M/C/K-DRM-LF Drum unit life (Y/M/C/Bk)
      Expresses how much of life has expired (as percentage).
      Appropriate values 0 to 100 (%)
      Note
      0% when new drum unit is inserted.
      both %'s are a little misleading /many conditions effect drum life/ some techs leave drum in over 200%
      or
      COPIER>DISPLAY>ALARM-1
      IMG-DT-Y/M/C/K - indicates the average of image ratios for copy/print jobs
      indicates the average image ratio (color ratio) within the drum unit
      • Fer
        • Nov 2009
        • 267
        I once had 4080 do 700%, that was over 160k for one black drum. It still was darker then IR5000 next to it.
        • SCREWTAPE
          East Coast Imaging
          • 3396
          700%???
          • teckat
            • 16083
            glitch/ in old firmware
            • SCREWTAPE
              East Coast Imaging
              • 3396
              Yea that's right.
              The highest % I seen is about 400 to 450%
              • android790
                • Jul 2010
                • 63
                I will replace the K drum when it hits 400 even if no cq flaws. I have guys that will clean the inside of the drum unit to pad there bei, but the black is not dark enuf 4 me. And I think the machine has to work too hard for its image. They may get another month out of it. Not worth it for me. I'm just lazy that way, and I know my customer will call back and say "its not dark like it used to be". Can't win so I won't try.
