booklet finisher c1 error
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 4999
    [Error Code] booklet finisher c1 error
    Hi
    i have an issue on booklet finisher c1 error 531-0001 advance series.
    Finisher is brand new.I check cables and connectors and use some grease
    but nothing happen.Any ideas??
  • mrfixit51
    Lead Service Technician
    • Oct 2008
    • 1975
    E531
    Staple motor(M41)/Staple home position detect switch
    8001 The stapler does not leave the staple home position when
    the staple motor has been driven for 0.4 sec.
    8002 The stapler does not return to the staple home position
    when the staple motor has been driven for 0.4 sec.
    Something is keeping the stapler from leaving or getting back home,,, investigate.
    • zoraldinho
      • Mar 2008
      • 4999
      Originally posted by mrfixit51
      E531
      Thanks for post.I change stapler and nothing happen.Problem was bad connector.
      • mrfixit51
        • Oct 2008
        • 1975
        Bad, as in loose connector,,, or bad, as in had to replace the controller board?
        • zoraldinho
          • Mar 2008
          • 4999
          Loose connector.
          • mrfixit51
            • Oct 2008
            • 1975
            Originally posted by zoraldinho
            Loose connector.
            Thanks for the update,, glad you have it resolved!!!
            • SCREWTAPE
              East Coast Imaging
              • 3396
              5 STARS
              Nice going.
