canon irc3200n prints nonsense
  • Dexter
    • May 2025
    [Electrical] canon irc3200n prints nonsense
    initially there was a slight difference of colors but the device worked perfectly in black
    and white
    regime a month ago the machine began to print "digital delirium (error device does not
    show!)
    ipicture.ru/uploads/100910/5qkrpp7Nfq.jpg characteristic imprint
    ipicture.ru/uploads/100910/7d1QQ8I2YJ.jpg 2 mark
    ipicture.ru/uploads/100924/jfS6Gy76DR.jpg accidentally imprinted a fragment with p-print
    ipicture.ru/uploads/100924/fVbUmw3tQb.jpg accidentally imprinted 2nd fragment with p-print
    ipicture.ru/uploads/100924/FIu5ARA3He.jpg accidentally imprinted copies of the fragment
    ipicture.ru/uploads/100924/Y71e5x1Sw0.gif pg-5 color test
    dens
    y - 0.84
    m - 1.26
    c - 1.05
    k-0.95
    window
    y-79
    m-97
    c-101
    k-98
    sgnl
    y - 158
    m - 126
    c - 192
    k - 110
    misc
    y-35
    m-37
    c-1
    k-208
    replaced the transfer belt cleaning unit, made a reset dc-con, r-con, mn-con, hdd has
    filled 90.03
    version, etc., etc. or anything not fundamentally change! prompt! help!
    • 16083
    and white
    show!)
    dens
    y - 0.84
    m - 1.26
    c - 1.05
    k-0.95
    window
    y-79
    m-97
    c-101
    k-98
    sgnl
    y - 158
    m - 126
    c - 192
    k - 110
    misc
    y-35
    m-37
    c-1
    k-208
    filled 90.03
    whatever jpg links u are trying to post, did not come out as links
    re-post pics
    digital delirium ?? what is that
    simple ?/ what is wrong ?
    text
    pictures
    combo of both
    marks
    moire'
    only color issues u posted are effected ?
    • Dexter
      http://www.ipicture.ru/uploads/100910/5qkrpp7Nfq.jpg characteristic imprint
      http://www.ipicture.ru/uploads/100924/jfS6Gy76DR.jpgaccidentally imprinted a fragment with p-print
      http://www.ipicture.ru/uploads/100924/fVbUmw3tQb.jpgaccidentally imprinted 2nd fragment with p-print
      http://www.ipicture.ru/uploads/100924/FIu5ARA3He.jpgaccidentally imprinted copies of the fragment
      http://www.ipicture.ru/uploads/100924/Y71e5x1Sw0.gifpg-5 color test
      • smiley
        • Aug 2008
        • 616
        hi have try to do an authogradtion full adjust?
        there is no glory without sacrifice
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5000
          Smells like image process issue.You need too investigate.Print some PG test prints.images.jpg
            • 16083
            how are glass prints color & b&w
            • SCREWTAPE
              East Coast Imaging
              • 3396
              P-prints are internal. So whatever is happening, its happening internally. Main controller could be at fault here or sub boards.
              • Dexter
                If you copy from the glass b / w original - we get b / w striped copy.
                if you copy the original color - respectively obtain a copy of the striped color.
                and this manifests itself when you copy the derivation of internal tests and network printing?!
                Can a black drum and chip (misc K-208) to block the normal operation of the machine??
                • Dexter
                  Main controller and sub boards are very expensive and so we would like to know exactly what it in them. How to specify where the problem and how chronic picture? where some chips? in which memory? on any registers? how and through what is transmitted as digital information on lasers? very very much like to understand
                    • 16083
                    forget about chips-
                    u need to evaluate the situation first/ answer some simple ?'s first/
                    if u are a tech. / u should have the original P PRINTS/ & User Prints on hand/ because u can't see images with your issue u need those orig .prints or copies of them
                    if so do a RCON CLR= DCON CLEAR/ turn off/on printer/ put back in the RCON #'s numbers & DCON #'s/
                    turn off/on printer -run a AUTO GRADATION/ CCD ADJUST/ then Remove cover over ITB Unit to view it /run a PG10
                    observe the ITB SHEET PG10 IMAGES / REPORT BACK
                    • Van Steal
                      • 177
                      Had a that look the same turned out to be faulty dc con pcb
                      • Herrmann
                        • Jan 2006
                        • 792
                        agree, laser control runnig wild, are you able to change the impb and/or the dc control against a known good one from another mashine?
                        If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
