Reset counter IR3300
  • arlf
    • Aug 2025
    Pls help me ,
    I want reset counter IR3300
    Thx for help me
  • teckat
    • 16083
    Originally posted by arlf
    Pls help me ,
    Thx for help me
    The counters are controlled by the main controller PCB
    TOTAL COUNTER IS FIXED=NO
    The type of soft counter 1 cannot be changed.
    101: total 1 (default: fixed to 101)
    Total Machine counters are not to be played with
    COPIER>FUNCTION>CLEAR
    CNT-MCON
    Use it to clear the soft counters for servicing on the main controller PCB.
    Using the Mode
    1) Select <CNT-MCON> to highlight, and press the OK key.
    2) Turn off and then on the main power switch.
    CNT-DCON
    Use it to clear the soft counter for servicing on the DC controller PCB.
    Using the Mode
    1) Select <CNT-DCON> to highlight, and press the OK key.
    Durables COUNTER can be cleared
    =yes
    • teckat
      • 16083
      the Counter Memory, Serial Number and Main Controller PCBs,
      work as a set and are considered the “Soft Counter Circuit”. The Counter Memory PCB is
      electronically stamped with the serial number from the Serial Number PCB. Neither the Counter Memory
      PCB nor the Serial Number PCB can be swapped to other equipment. The Counter Memory PCB keeps track
      of the total count, which cannot be erased or changed.
      The service counters are retained by the Main
      Controller. These counters can be reset manually through service mode. When the Counter Memory PCB
      must be replaced, after installing the new one, the new Counter Memory PCB learns the Total Count from the
      Main Controller. This is retained in SRAM on the Main Controller PCB and held active by means of an on
      board battery.
      Never replace two boards in the Soft Counter circuit at the same time! This would include any
      two of either the Counter Memory PCB, Main Controller PCB (or Image Processor depending on
      model) and Serial Number PCB
      It is illegal to tamper with this circuit in an attempt to falsify the counter readings of any Canon
      Copier.
      • SCREWTAPE
        East Coast Imaging
        • 3396
        That's a no nooooo..
        That's FRAUD.
        • zoraldinho
          teacher-guide-expert-guru
          • Mar 2008
          • 5015
          Pls help me ,
          Thx for help me
          Your 2 post is reset counter.This is copytechnet not garagedealernet.
          • mrwho
            Major Asshole!
            • 4299
            Pls help me ,
            Thx for help me
            I wrote a detailed procedure for that over here. Be sure to follow it thoroughly.
            Mascan42
            Ibid
            • zoraldinho
              • Mar 2008
              • 5015
              Ha ha ha.I almost piss.
              • teckat
                • 16083
                soft counters can be cleared/ except for Total 101
                • Canuck
                  Tech Specialist
                  • 1713
                  Pls help me ,
                  Thx for help me
                  replace these components:all circuit boards,pick up assemblies,dev,drum unit,reader assembly,adf,laser,fuser assembly,machine frame,all wiring,sensors,connectors....
                  • Randy G
                    Could be? to reset counter? sounds like good.
                    • teckat
                      • 16083
                      • SCREWTAPE
                        East Coast Imaging
                        • 3396
                        Stupid is , stupid does.
                        • sqrt
                          Re: Reset counter IR3300
                          1.program counter and serial
                          or
                          2.remove battery and ( ! C1008 = 0V ) Replace
                          2.1 counter
                          2.2 battery 3.3v
                          • teckat
                            • 16083
                            or
                            2.1 counter
                            2.2 battery 3.3v
                            first off/ this post is from 10-03-2010
                            second/u don't know what you're talking about
                            CNT-MCON
                            Using the Mode
                            CNT-DCON
                            Using the Mode
                            =yes
                            board battery.
                            Copier.
