Canon IPF 810
  • xcopytech
    • Aug 2006
    • 1794
    Canon IPF 810
    Have hardware error 03130031-2f26 on canon IPF 810.
    If someone have service manual for this machine we can arrange some exchange for Xerox, Canon and Toshiba manuals.
    Thanks in advance.
  • teckat
    • 16083
    Thanks in advance.
    error code 03130031-2F26
    Micro cracks can cause numerous problems and intermittent random error codes. Using the Flexible Flat Cable Checker (FCC Checker) would be a good idea to find out about the condition of the Flex Cable
    code can be caused by the encoder sensor on the carriage assembly or the carriage assembly not being able to move correctly. If the carriage assembly can move normally try cleaning the linear encoder sensor. If cleaning the linear encoder sensor does not resolve the error check the flex cable next. This sensor is connected through the flex cable.
    Replacing the flex cable has resolved this problem.
    Check the Carriage Assembly , it contains bronze bushings which require no lubrication. Customers must be instructed to refrain from lubricating the Carriage Rail, and to clean any dirt, grease, or oil that had accumulated. They should always install the new rail cleaner included with each new Maintenance Cartridge, whenever the Maintenance Cartridge is changed.
    Currently a new Carriage Rail Cleaner is included with each new Maintenance Cartridge. Customer may not always replace the cleaner or inadvertently discard it with the Maintenance Cartridge box
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5007
      Try cleaning the linear encoder sensor.In 90% is this the issue.
      • teckat
        • 16083
        too late / has been advised already
        • zoraldinho
          • Mar 2008
          • 5007
          • teckat
            • 16083
            no me Turkishman/ see below
            • xcopytech
              • Aug 2006
              • 1794
              Thanks for answers.
              Will try and post result here.
              If someone have service manual please contact me at PM
              • tungtin
                I have IPF-810 service manual.
                I need Xerox Docucentre service manual.
                My email: tungtin@rocketmail.com
                • teckat
                  • 16083
                  send poster
                  a PM on your offer xcopytech
