HD problem
  • Harry
    • 228
    [Dead] HD problem
    Is there anybody out there!
    Have sst 3.35 and need to change HD.Edit ift to my WD800BEVE-00A0HT0.sst error no disk match mayby HDPI is wrong i dont know and please help!Make this kind of work more then one year agoo with my old toshi laptop disk and it work just fine where is the mistake i have to anderstand. Is there a way to modificate the whole ift to rignosize every disk?
    Thank you in advance every Idea is ok iam in the Shit now.
    PS Iam a Tech but not speciali Canon but i have 3 of them all crape with E 602 0001
    thank you again
  • RRodgers
    • Jun 2009
    • 1947
    Modificate, nice!
    Sounds like are in dee chit,
    Good luck!
    • fusker
      • Aug 2010
      • 19
      For *.ift no need to modify that files. *.ift is contain information loader file that refer to *.prg files. its like your firmaware is does match with your machine series,
      • Fer
        • Nov 2009
        • 267
        I don;t know exactly how to, but i heard of people editing the Format file in SST. Adding the drive make or model to it.
        • Harry
          • 228
          OK i have the process to edit file in hd ....13 but with this hd not working. Is ther anybody who mount;edit and Format this HD without error in SST 35????
          the Firmware is 4.45 and also today with the other copier it works fine.Format and updated the old hd.
          thank you at all the best forum at the world
          Ps thanks MR Rrodgers for your comment if you want it German
          Ich sitze in der Scheisse
          Saluti
          • teckat
            • 16083
            Saluti
            what model printer do you have ?
            SST ERROR #35 = is a Write Protection Error/Media is Write Protected/=Release the Media's Write Protection
            SST_-_HDD_Not_Found.pdf
            • Harry
              • 228
              Ok Thank you my error in sst is 150 the model is IR 2800 its not a network printer
              thak you for your pdf i take the instructions from this is ther a way to get this Hd work?
              • teckat
                • 16083
                Ok !
                ERROR 150=is
                HDD format unsupported error/
                installed HDD is not supported/
                install supported HDD/
                check if HDFormat file for your model is registered in SST
                • Harry
                  • 228
                  thank you i have sst manual also today i change something in ift and get runtime error 9 script is out of range. reduce the file at minimum so the 150 error is gone.
                  i ordered two hd inside the list maybe i have time another day to turn how to crack
                  this program it is very good fore my own knowlege and for the others too.
                  thank you at all
                  • Randy G
                    its sound likes your drive is too bigger, or incompatible..
                    • teckat
                      • 16083
                      Remember the HDD size is 5.1 GB Hard Drive and 128 MB standard with shared memory for copy and print
                      functions on the imageRUNNER 2200/2800/3300
                      Available HDFormat is now v00.16= iR2200/2800/3300
