iRC3220 Magenta Background
  • imagewalker
    • Jun 2010
    • 94
    iRC3220 Magenta Background using 11x17 in by-pass heavy stock paper,mostly front side of machine has background almost like the drum is grounding or too much bias.
    only happens to magenta in heavy stock paper after 20 copies.
    any ideas???? drum life is 83%
    Too much compensation for heaver stock for magenta.....?.
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Try Performing the auto gradation, full, using the THICK PAPER button selected.
    Are you selecting heavy type?
    Your drum life percentage is kind of high as well.
    • teckat
      • 16083
      those %#'s are misleading- if u are printing over 6% to 10% coverage on 11x17 stock/ your Drums will eventually crap out- u just have to pull out magenta drum an look at surface/ if dark areas appear on surface, there is your background issue =causes overtone & background
      • imagewalker
        • Jun 2010
        • 94
        Umm... Question: Copier drum life means that the percentage of life remaining or the amount of drum life used.. ? thought it was remaining like Xerox
        • teckat
          • 16083
          Fairy Tales of Canon/ inspect Drum Surface
          Do an Auto Calibrate once & a while
          • smiley
            • Aug 2008
            • 616
            sometimes you have to upgrade your dc controler. i have 3220 doing this also new drum install after 20 copys same problem occur.its like overtone at 1% drum life.
            there is no glory without sacrifice
            • badboys
              • Oct 2010
              • 69
              Are you a tech? If you're one then dismantle the magenta drum unit. Clean the primary roller area & remove accessive toner. Upgrading DC-Con version is recommended (ver37 or higher). 83% drum lifespan is still acceptable if you're a heavy & massive user. If none of the recommendation works, then replace the drum unit. Go to service mode>Copier>Option>Body>scroll down & set>DVTG-M value to +2>OK.(after replacing the drum unit)......good luck.
              • teckat
                • 16083
                that setting does not have any effect/ all u need to do is inspect drum surface/ it will reveal if u will have background issues/
                I had 240 of these 3220 machines at one Major account/ those Level 1/ Level 2 settings are a waste of time when it comes to image issues.
                that Drum% rating is a waste/ Canon Still cant get their act straight trying to explain it
                • badboys
                  • Oct 2010
                  • 69
                  ...at least mine works. 540% of drum lifespan & still rolling.
                  (Extreme & massive cutomer of mine. Their monthly copy volume = 50-70k...simply amazing)
                  • teckat
                    • 16083
                    50k>70k that is nothing/
                    that Major acct I mentioned/ avg. monthly volume on each 3220 was 125k>135k - without playing around with service mode settings.
                    like I said that %
                    reading is not correct/misleading & and a software glitch that effects many 3220 serial # machines / Firmware updates do not repair or have effect on a very large batch of 3220's
                    • SCREWTAPE
                      East Coast Imaging
                      • 3396
                      Here is another tip when using heavy paper. As I posted before. The auto gradation adjustment by paper type (plain or heavy) is available with this model. When this type of symptom occurs, you can try to perform the adjustment as follows:
                      1. Set 3 or more sheets of heavy paper (blank page) in a cassette.
                      2. In user mode [Adjustment/Cleaning > Auto Gradation Adjustment > Heavy 1/ Heavy 2 (106 to 253g/m2) > Start].
                      • badboys
                        • Oct 2010
                        • 69
                        125>135k a month...??? Simply outstanding BUT it's a lot to much for it to handle. Don't you think so? It's being abuse....well, what I mean is that the recommended monthly copy volume for IRC3200/3220 is only 50>60k...???
                        • teckat
                          • 16083
                          no one pays attention to that brochure crap/ especially Sales People
                          • blazebusiness
                            SanDiegoCopierRepair.com
                            • 1250
                            Don't waste your time with disassembly. Replace the indicated drum & be done with the problem. Follow screwtapes instruction doing the grad adj with heavy stock.
                            • SCREWTAPE
                              East Coast Imaging
                              • 3396
                              Preach it.
                              That's funny and so true.
