IR105 finsher
  • copy_suhail
    • 88
    IR105 finsher
    I have IR105 with error (the finisher cant use) and i see that the two trays did not checking when the machine turn on , but the finisher and stapler work ok.
    thanks
  • iust
    • Jul 2008
    • 58
    no problem
    u most open finisher front door . and found small door in left side . in the case is mechanical keys u back every keys in ON mode.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      thanks
      the finisher cant use is not an error.Check error codes.Probably you have a limited
      function mode.
      • jzheld
        • Sep 2010
        • 162
        thanks
        witch trays?
        • copy_suhail
          • 88
          Originally posted by jzheld
          witch trays?
          Tray A
          • jzheld
            • Sep 2010
            • 162
            check the connections, cable might be bad
            • SCREWTAPE
              East Coast Imaging
              • 3396
              What???
              Are you talking the "Dip Switches".
              And let's say he puts them all on!
              Then what?
              • SCREWTAPE
                East Coast Imaging
                • 3396
                thanks
                The stapler works , but the machine says "Finisher can't be used".
                UMMM...
                If you go into service mode do you see "SORTER"
                What about error codes. Are there any in the ERR history.
                • copy_suhail
                  • 88
                  UMMM...
                  No there is no error
                  • SCREWTAPE
                    East Coast Imaging
                    • 3396
                    Do you see Sorter when you go into service mode.
                    Copier
                    Feeder
                    Sorter
                    Board.
                    • copy_suhail
                      • 88
                      Copier
                      Feeder
                      Sorter
                      Board.
                      Yes I do
                      • SCREWTAPE
                        East Coast Imaging
                        • 3396
                        Yes I do
                        Which sorter do you have.
                        Saddle or just the finisher.
                        • SCREWTAPE
                          East Coast Imaging
                          • 3396
                          There are no error codes. Is there a E713??
                          There are two possible causes that would display this message.
                          To isolate between the two possible causes, check to see if the imageRUNNER is communicating with the Finisher. This can be done through Service Mode>Copier>Display>and check to see that IC106 & IC125 both display a Version Number.
                          1st Cause:
                          If a Version Number is PRESENT, check to see that Bit 2 on SW971 is switched to "ON" position.
                          2nd Cause:
                          If a Version Number is NOT PRESENT, check to see if 5 volts is present at J101 - Pin 3, on the Finisher Controller. The missing 5 volts will cause no communication and generate the message.
                          To Troubleshoot for the missing 5 volts:
                          Check for 5 volts at J714 - Pin 7, of the Fuse PCB. If the 5 volts is missing, check J711 - Pin 1, of the Fuse PCB for 5 volts. If 5 volts is present at J711 - Pin 1, replace the Fuse PCB, if missing, replace the Finisher Power Supply.
                          • copy_suhail
                            • 88
                            1st Cause:
                            2nd Cause:
                            Thank you sir I will check that today.
