Canon C1 4 color dots across page
  • Penvy
    • Oct 2008
    • 228
    Cant figure out these small dots Y-M-C-K left to Right , printing in color
    in that order about 1/8" apart never in the same area but on same line
    repeats on 11x17 same line as if it was on the drum rotation.
    Replaced the Drum and ITB same thing!
    Not Drum or ITB!
    New drum
    New Itb
    Very clean
    inside
    Dev units good
    Laser?
    print blank page and no dots!
    Print B&W Just the Black dot same line
    Print from server color ,same thing 4 dots
    print from Scanner color, same thing 4 dots y-m-c-k
    Print 12X18 and more dots same line and little bigger dot
    Great color just the dots
    HELP!
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5020
    HI Penvy.
    My opinion is primary corona issue.First change corona grid,if no better replace corona assy.
    • SCREWTAPE
      East Coast Imaging
      • 3371
      Do they look like this. The dots are created by pit marks on the Drum caused by contamination in the Developer Units. Or a bad drum. But you change the drum right.
      • Penvy
        • Oct 2008
        • 228
        Yes this is it,
        New drum
        Dev units restarted, cleaned less that 100k
        New ITB
        And did the inst4 for the Dev units
        these dots were exactly the same before the drum change
        Everything was cleaned top to bottom.
        I will inspect the New drum but the dots were there before and that same.
        • Penvy
          • Oct 2008
          • 228
          This drum was brand new.
          And i did find a pit mark
          I did everything by the book.
          You have to turn on the mach to get it started to reset.
          Did what the manual said to reset
          New Carona wire and Grid w/less that 5K
          The contamination from the Dev units?
          there not even 100k and have been cleaned and restarted I mean VERY clean!!!
          good brush and color was great.
          Pitting a brand new drum. or was the Drum defective?
          This C1 is a real POS
          But what great color when it works
          This is where I really need some advice on this drum issue
          And replacement
          What did I do wrong?
          • teckat
            • 16081
            And replacement
            Four Scratch Marks Caused by the Pre-Transfer Corona and Four Dots Caused by a Foreign Object
            The Four Dot Marks reproduced on prints are a result of foreign object in the Developing Assembly, Drum
            Cleaning Assembly and in some cases, the Image Scan Patch Sensor. This foreign object strikes the Drum
            during the development process, damaging the Drum.
            Four Scratch Marks:
            The Four Scratch Marks reproduced on prints are as a result of the rear guide on the Pre-Transfer Corona
            breaking, causing the Pre-Transfer Corona to drop down scratching the Drum.
            The Scratch Marks look
            similar to the Four Dot Markings and can be easily mistaken for the Four Dot issue.
            The Four Dot Marks can be resolved by vacuuming the Developer Assemblies, Cleaning Assemblies and
            opening and cleaning the Image Scan Patch Sensor.
            READ PDF BELOW
            C1-TP09-2.pdf
            • Penvy
              • Oct 2008
              • 228
              All of that was done,
              really cleaned the heck out of the Dev units and everything in the drum and dev areas
              replaced the seals and cleaning blades
              Patch sensors
              Everything
              And theres those friggin dots just like you showed in the PDF
              at the bottom.
              This is really heartbreaking to spend all this money and time just to see this fail from a fresh start by replacing almost everything
              except the copier itself.
              The Dev units dont even have 80K but have been cleaned very carefully and use the right starter and resetting the drum and inst-4 for the dev units
              the prim wire is new and grid cleaned.
              very careful on install.
              but right from the start this pit in the drum first time.
              how can you even repair this when its all new?
              the Dev units are as clean as brand new.
              The image patch sensor and everything top to bottom was vac cleaned spotless soon as you turn on this goes into the auto gradation even befor you can start to set up the new parts.
              what gives here?
              I did everything that tech memo said to do.
              How do you replace a drum then??????
              no foreign objects on a clean mach
              where?
              very frustrated with this
              • teckat
                • 16081
                once the Drum is pitted that is it, no repair
                REPLACE THE GUIDE/ IT IS WARPED
                pre-transfer corona guide is the issue/
                u need to replace the guide / it's the position of the guide when u slide in corona unit/
                the end block hits drum when u push it in
                • zoraldinho
                  • Mar 2008
                  • 5020
                  Nail on the head.95%.
                  • Penvy
                    • Oct 2008
                    • 228
                    I understand that guide,
                    No I am aware of that and its not warped and what it is pushed in very slow and deliberate.
                    Top and bottom .
                    This is a pit that looks as if it was an arc.
                    But just shoot me.
                    SHIT
                    • teckat
                      • 16081
                      Top and bottom .
                      But just shoot me.
                      SHIT
                      even if u push in the corona very slow/ for some reason it rises up and hits drum/ & replaced guide over ten times already /
                      primary blocks can have ARC marks/ inspect
                      • Penvy
                        • Oct 2008
                        • 228
                        This ones just kicking my ass I will inspect carefully top and bottom carona's
                        the old drum had them too
                        Brand new drum.SHHHHITTTT.
                        Been doing this a long time and by far this C1 just is the worst in overall design
                        Great color, slow but really beautiful color match
                        but just a real POS to keep running.
                        Canon really messed up with this one
                        Just too easy to break on its own.
                        the best I have seen is 60K before meltdown
                        The top guide is very secure and little movement
                        The bottom one just did not feel any contact.
                        • SCREWTAPE
                          East Coast Imaging
                          • 3371
                          I hear ya on the C1.
                          Wait till work on the Advance models.
                          You will love it.
                          • Penvy
                            • Oct 2008
                            • 228
                            Lets review this clusterF of a mach
                            New prim and grid 5K ago
                            New pre wire 5K
                            Dev restarted and very clean
                            Clean toner path tubes to the hopper
                            Even pulled the doctor blade inside Gap to 80Lb Business card paper for proper brush
                            Clean ATR and DEV assy
                            HV prim 999
                            Grid 464
                            Inst-4 for Dev
                            NewITB and cleaned rollers and cleaning rollers
                            new drum w/all new seals and cleaning blade
                            Reset Drum
                            printed full p5 color to get Dev dens
                            no errors
                            very careful on install of prim and pre
                            ITB reset
                            DFC
                            Dev inst-4
                            drum potential
                            very clean on inside pathway and frame
                            I just dont see how the carona slide very slow install even touched the drum
                            Just this little pin hole with the 4 dots on the print
                            Somewhere this drum got a spike from somewhere
                            What am i missing other that another new drum
                            • teckat
                              • 16081
                              if u work for an authorized dealer, call Canon tec. support>explain issue of pin hole in Drum, document your findings with copies & test prints & copy of service log. They will issue a new Drum, but they will recommend u replace all four developers.
                              I used to Call a friend in Canon Engineering, but he has since left. I will call them tomorrow to see if I can get some more info on this pin hole dilemma.
                              <High Primary corona output can cause a pinhole in Drum>
