Original detect issue, IR5570
  • Holesaletech27
    • Jul 2009
    • 101
    I had 2 of these refurbed for resale, HDD, RAM clear, new meter PCB... Now detecting originals on the glass always selects the larger paper size(11x8.5 reads 11x17, 8.5x11 reads 8.5x14). I'm guessing it has something to do with the settings, I reinput the values from the chat inside the front cover(didn't help). Any ideas? Also, is there a way to just disable the auto original detect? Always easy to find on other brand copier, but I can't locate it on the Canons...I wasn't the one who refurbed them, and our in-house Canon tech doesn't know.. Thanks in advance!
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    Check in level 2 Service Mode > Copier > Option > Body > SENS-CNF ----------If it is set to 0 change it to 1 and restart copier.
    If you want to take the copier out of auto detect paper size--------select a default paper drawer on the display ------then go to user settings by hitting * and lock that setting in by storing the default copier settings
    • Holesaletech27
      • Jul 2009
      • 101
      Thanks! I'll give it a go whenI go back and let you know howit worked out.
      • blazebusiness
        • 1250
        Good Luck!
        • SCREWTAPE
          East Coast Imaging
          • 3396
          Ding,Ding,Ding,Ding
          You're right...
          • blazebusiness
            • 1250
            LOL Me smart sometimes.............
            • blazebusiness
              • 1250
              Probably part of the refurb. It's my understanding that Canon under certain circumstances will let you put a new counter if the unit is reconditioned according to their requirements. Don't know much about that program now but in the 1990's the Canon dealer I worked for (Remco Business Products-which later was bought out by alco standard which became Ikon) refurbed a lot of units and resold them with a zero meter with Canon's approval.
              • Holesaletech27
                • Jul 2009
                • 101
                Yes, we have a checklist that we go by on what to replace and such. Under contract to refurb them, so the list comes from that company.
                • teckat
                  • 16083
                  READ
                  Counter Memory_TP05 108c[1].pdf
                  • blazebusiness
                    • 1250
                    I would be interested to know what Canon requires you do to refurb those units. Can you post the list of what is required of you?
                    • Canuck
                      Tech Specialist
                      • 1713
                      As per Teckat's post,replacing the counter pcb does not zero the machine...read the bulletin....Canon provides no means to zero the machine
                      • SCREWTAPE
                        East Coast Imaging
                        • 3396
                        Very true.
                        My ? is , why would they do something like that. IDK
