E00001-0003
  • Jay Jonach
    • Aug 2025
    [Error Code] E00001-0003
    Walked in today and turned on copier...Got this error code. can someone help?
  • CanonSco
    Man About Town
    • Jul 2010
    • 368
    Gonna need at least a little info
    What model would be a good start.
    Yes, I am a nerd.
    Gaming PC - check. Raspberry Pi - Check. Custom ROM on phone - check. Thick glasses - check.
    • Jay Jonach
      Cannon C2620
      I have a c2620 that when I turn it on I get a error code E00001-0003. It say to turn on/off on side of unit, which I have done but still get the same code.
      • blazebusiness
        SanDiegoCopierRepair.com
        • 1257
        Reset the code in service mode & then cycle power. If problem does not return .....could have been a fluke. If problem continues check component & connectors.
        • Jay Jonach
          how do I get to service mode
          • blazebusiness
            • 1257
            Oops-thought u were a tech--- *28*. Then function-error-clr. If you not a tech and are going to work on this machine....download the service manual online from somebody & familiarize yourself with service mode before you attempt to use it.
            • Jay Jonach
              when I do 28 I go to download mode
              • blazebusiness
                • 1257
                do a google search for the IR C3220 service manual & download it and familiarize yourself with service mode. The books are available for immediate download in pdf format and only cost about $12. If you are going to work on your own machine its a good investment.
                You don't want download mode.
                When you hit *28* a service mode screen should come up with tabs at the top. Select function tab then Clear then err and hit ok. Cycle power.
                • Jay Jonach
                  Thanks for the help...not getting very far..
                  Maybe its how I am doing it. I turn on unit, after two loading screans I get the errow screen. I push *28* and nothing happens. Please clarify.
                  In the mean time I will try to get service manual.
                  • blazebusiness
                    • 1257
                    You must have held down the 2 & 8 keys while turning on pwr to enter download mode - which was not my advice....thats why you should download the book my friend!
                    • Ikon Princess
                      • 126
                      I think you should place a service call and maybe your tech can talk you through it.
                      • blazebusiness
                        • 1257
                        To clarify things---------from the main copier ready screen hit the asterisk to the left of number pad, then release it and hold down the 2 and the 8 at the same time, then release them and hit asterisk. Boom- you are in service mode and can do the function - clr - err procedure. Good luck - hope that helps.
                        • collme
                          Ricoh tech
                          • 221
                          press user function key, then 2 and 8 together, then press user function key again, should get you into service mode. only do this when it has booted up to the error screen. user function key is the star in a head shape key. only goto tab mentioned earlier and clear as you can do more harm than good if you mess around with some settings. if error re occurs you will need a tech, as it is a fuser unit abnormality and will need parts.
                          • SCREWTAPE
                            East Coast Imaging
                            • 3396
                            Jay.
                            *Additional functions > 2&8 (At the same time) >*Additional funtions> Copier>function>clear>err>ok>reboot.
                            You must be fast once the code pops up.
                            Sometimes if you hit the reset button and try again it goes into service mode.
                            Let me know how you feel about having a tech look at your machine.
                            • blazebusiness
                              • 1257
                              I thought it worthwhile to add extra emphasis to collme's warning to only go to the tabs and settings mentioned to clear your error. Don't change or clear other stuff in service mode-----
                              PS Did you get that manual? here's a link http://www.smpcshop.com/iR-C3200-iR-...20-p-1779.html to one of many sites you can buy it from. Don't let the model # throw you...It's the same model you have.
