cannon error code e014
  • muddassir
    sir,
    i am using cannon ir 400 my problem is that since 2days i am getting error code e014 plz reply
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    Originally posted by muddassir
    sir,
    Is the problem interrmittant or comes up every time when you turn the copier on?
    You'll need to remove the fuser from the copier and inspect it to see if it is binding up making it difficult for the fuser drive motor to turn it. Lubricate any gears thet are gummed up and not turning well. Pay special attention to the swing plate assy. Also check for frozen bearings,flat spots on lower fuser roller, or anything else that can restrict fuser movement.
    If that doesn't fix it - you may need a new motor - but that is almost never the case.
    • mrfixit51
      Lead Service Technician
      • Oct 2008
      • 1975
      I am pretty sure that Blaze has provided you the answer, the swing plate on the front to the fuser has the input drive gears on it,,, the shafts/gears get gummed up making the fuser very hard to turn, causing the E014 you described. Pull it apart, clean and lube the gear pivots. I use automatic transmission fluid instead of oil,, it never gums up!
      • blazebusiness
        • 1250
        Very interesting tip - that transmission fluid. Curious -Do you still use oil at all in the copier to lubricate other stuff?
        • badboys
          • Oct 2010
          • 69
          You might also want to look into the solenoid that control the rotation of the web supply roll. Assess it from the from, hidden in the frame cover....good luck....
          • mrfixit51
            • Oct 2008
            • 1975
            I use the tranny fluid as my only oil type lubricant,,, this advice came from one of my Canon instructors, many years ago...
            • mrfixit51
              • Oct 2008
              • 1975
              Originally posted by badboys
              You might also want to look into the solenoid that control the rotation of the web supply roll. Assess it from the front, hidden in the frame cover....good luck....
              While it is a good idea to check on this web advance mechanism once in awhile, especially the 550 and 5000 series machines,, the web advance has no bearing on the E014 problems...
              • mecho
                sir,
                normally this error due to your lower fixing has jammed,you can lubricates it or replace
                • Canuck
                  Tech Specialist
                  • 1713
                  Re: cannon error code e014
                  Upgrade!! Obviously Canon instructors don't know much...transmission fluid is a poor lubricant...its purpose is to transmit hydraulic pressure. Put some Ford transmission fluid into a GM turbo-hydramatic and tell me if it shifts good...... NOT.... Different fluids have different frictional properties. I started as a mechanic back in 1982.
