ir 2270 system settings password
  • lightningjeremy
    • Jul 2009
    • 139
    i have a customer that has been pushing some buttons they shouldnt have. is there a way to get around a password set for the system settings? thanx
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1257
    Go to service mode >function>PWD-CLR
    Clearing the password of the system administrator set in user mode
    The password is cleared when the OK key is pressed.
    • costd
      • Jan 2008
      • 409
      You need to note that the password will be cleared - as in if you are a user trying to get around restrictions, the system administrator will know. If you are a tech, the online training for this series covers this common issue - might want to run through it right quick.
      • lightningjeremy
        • Jul 2009
        • 139
        thanx for the responses
