Canon IR2018 fixing film replacement
  • mnamono
    • Jul 2025
    [Misc] Canon IR2018 fixing film replacement
    Hi guys,
    Im an IT support officer. Im good with laser printers but when it comes to copiers............I still need help from experts....unless I have a service manual.
    Well here's my problem. I have a Canon IR2018 MFD copier. It started giving me the e007 error. I know this has somthing to do with the fixing film. I did try to reset it thinking the heat sensors have detected high temp....but still same error message. I've just orderd a new fixing film......but the crazy thing is that I dont know where to start..........my copier supports duplex. Where can I find the fixing film?? is it on the rear door?? I noticed there are two units there.....I believe one is for duplex (the top one). Does anyone have a service manual or a technical diagram of a canon ir2018 copier.....that would help alot.
    I just need somthing to start me of on the right track.
    Thanks a million.
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Removing the Fixing Unit. Photos are in order from 1 to 4
    1) Remove the two screws [1], and then detach the inner cover [2] at the upper front. 1 step
    2) Remove the screw [1], and then detach the heater harness cover [2]. Disconnect the connector [3]. 2 step
    3) Disconnect the two connectors [1], and then release the fixing unit harness from the wire saddle [2]. 3 step
    4) Raise the delivery upper guide [1]. Remove the three screws [2], and then remove the fixing unit [3]. 4 step
