IRC2380 colours out of sync
  • shazza
    • Nov 2009
    • 96
    #16
    Hi ,
    Hi Guys, Ive got an IRC2380 out there where the colour registration keeps going out of sync. After adjusting up the colour registration for each colour it lasts for about a week and then goes out of sync again giving a sort of 3D effect.
    Anyone had this fault or got any ideas.
    Cheers guys....
    Any Joy yet and find the cure? We have the same problem with a machine and Drum Drive assy,Itb,itb cleaner changed twice bt previous engineers.
    Still comes back after about 30k
    Cheers,
    Shazza
    • teckat
      • 16083
      #17
      Originally posted by shazza
      Hi ,
      Cheers guys....
      Cheers,
      Shazza
      see above>>>>>>>>>>>>>
      Check the ITB / Drum Drive Assembly
      • shazza
        • Nov 2009
        • 96
        #18
        hi Teket,
        Both have been replaced twice and problem still exists
        • teckat
          • 16083
          #19
          Cheers guys....
          Remove the noise dampening pad for the Registration sensor flag and then performing Reg-Clear, Quick Adjust and then adjusting the IMG-REG
          or
          Try clearing out the Registration Data stored in the DC Controller. To clear the data, perform the following.
          Enter Service Mode: Level 2 > Copier > Function > Clear > Reg/Clear. Highlight Reg/Clear and press OK.
          After performing the clear, reboot the machine and perform a Gradation Quick Adjust and then a Full Gradation adjust.
          Note*
          Following the above instructions above could prevent you from having to perform a DC-CON clear, and inputting all DC-CON values from the door label.
          do u have this on the 2380
          Addition Functions > Adjustments and Cleaning > Auto Color Mismatch Correction
