iPRC7000VP E020-0281
  • hasan5900
    • Dec 2015
    • 13
    #16
    Re: iPRC7000VP E0822-1603-05
    Please place pictures Wayne van unemployed Please
    • teckat
      • 16083
      #17
      explain ?
      there are no pictures
      what section where u working on
      are you certain about this code
      • hasan5900
        • Dec 2015
        • 13
        #18
        Yes sure this is the code please help
        • teckat
          • 16083
          #19
          SIMPLE QUESTION
          What printer area / areas were you working on before this error code
          there is no fan location for that error code
          E0822-1603
          code is actually E822-1603 CHECK CODE AGAIN
          THERE ARE OVER 70 FANS IN MAIN SECTIONS OF PRINTER
          • hasan5900
            • Dec 2015
            • 13
            #20
            I have verified the symbol which is the same symbol
            • teckat
              • 16083
              #21
              [ATTACH=CONFIG]33841[/ATTACH]
              trace your work steps before code
              error code is not listed anywhere--------------------NOW CALL CANON in your area
              • digital5
                • Aug 2016
                • 5
                #22
                Canon ImagePress 7010 Service Manual revision 0 110410
                Hi any access to to revison manual Canon ImagePress 7010 Service Manual revision 0 110410,
                trying to fix error E822-1603, its referring to a fan that has been modified from C7000 to C7010
                • hasan5900
                  • Dec 2015
                  • 13
                  #23
                  Hello, please do not know the mistake I hope that you let me know any idle fan
                  • teckat
                    • 16083
                    #24
                    no information/ contact Canon in your area
                    Check for any disconnection/improper connection on any fans in areas u were working
                    E822 ===Error in a Delivery Fan ----
                    When detecting phase unlock for 2 sec consecutively when 10 sec elapsed after the fan was turned on
                    -1603===no 603 "FAN" number listed in any pubs. or manual or updates on any imagePress models.
                    1: means it's a detection at power on ------bet you have a unplugged or poor connection
                    -05
                    ===location is Printer.
                    • digital5
                      • Aug 2016
                      • 5
                      #25
                      -05
                      Moved to new premises, put machine together, error E0822-1603, originally machine was 7000vp but upgraded to 7010vp, so the fan has been replaced as per image
                      error E00822-1603.jpgso how do i reset the machine to the new config, the 7010vp service manual is referring me to Service manual Rev 0 110410 so if anyone has access a copy would be appreciated
                      • teckat
                        • 16083
                        #26
                        [ATTACH=CONFIG]33919[/ATTACH]so how do i reset the machine to the new config, the 7010vp service manual is referring me to Service manual Rev 0 110410 so if anyone has access a copy would be appreciated
                        Who told u that u can convet. 7000 to 7010_?
                        By adding a fan.
                        Call the person.
                        • digital5
                          • Aug 2016
                          • 5
                          #27
                          By adding a fan.
                          Call the person.
                          seriously, i need a resolution to a issue, and you are making it petty,i don't have the time or the mindset for this sort of crap
                          • teckat
                            • 16083
                            #28
                            the only resolution u deserve " Get an Education on the Products you Tamper With "
                            "You created that ERROR CODE"
                            • digital5
                              • Aug 2016
                              • 5
                              #29
                              Re: iPRC7000VP E020-0281
                              thank you, I could express i opinion in more colourful language but i wont bother
                              • teckat
                                • 16083
                                #30
                                Stop wasting time on this forum.
                                You plainly show that you are not a tech, but a wanabe person.
                                I have fired many a person like you.
                                You personally create a error situation on a printer, and now expect someone in this forum to resolve your bad habits.
