irc 5185-duplex
  • roho
    • Mar 2009
    • 844
    [Jamming] irc 5185-duplex
    Good afternoon! Getting 0205,0105 jams-ltr size paper only-duplex. A tech has already replaced dc controller 2-seems as though that was temporary solution. All other sizes feed through no prob-thinking of the duplex step motor.
    I was wondering if anybody could let me know if they had similiar issues, or any advice for this issue.
    Thanks!
  • SCREWTAPE
    East Coast Imaging
    • 3396
    Check the wire harrnes connector on that duplex motor.
    Reseat the connector
    That's M26, Parts CHK #17 DCON2 J119B
    0105,0205-This jam code refers to the registration sensor delay. Check your feed and sep rollers. Check your registration area, It could be a timing issue.
    • teckat
      • 16092
      Thanks!
      is this a issue when u use the DADF for Duplex - or when u send Network Prints to Duplex ?
      or both/
      • teckat
        • 16092
        good afternoon! Getting 0205,0105 jams-ltr size paper only-duplex. A tech has already replaced dc controller 2-seems as though that was temporary solution. All other sizes feed through no prob-thinking of the duplex step motor.
        Thanks!
        check pic below
        [ATTACH=CONFIG]6828[/ATTACH]
        • teckat
          • 16092
          Thanks!
          To add
          When duplex copying, the swing arm of the duplexing assembly could malfunction, causing the jam code "0205"
          Check the swing arm and the 16T gear
          Jam- 0205 can be displayed when a stationary jam occurs at the registration sensor (PS26).
          replace the swing guide with a new one. If the symptom still occurs, replace the 16T gear with a new one.
          FU7-0204-000=16T Gear
          FC6-8693-000=Swing Arm
          FL2-4237-000=SIDE PLATE, DUPLEXING DRIVE
          • roho
            • Mar 2009
            • 844
            Thanks! After checking on all these suggestions, the duplex motor was the culprit!
            • SCREWTAPE
              East Coast Imaging
              • 3396
              Thanks for posting your solution.
              Good work
