IR 3035
  • bobthecopierman
    • Mar 2010
    • 53
    [Jamming] IR 3035
    Right side door on IR 3035 is bowed out or warped. When you close the door you can see the panel sticking out about a 1/2 inch from the frame on the middle section of the door by the release button. It is causing jams on 2 sided copies. I can put pressure at the warped section and it will feed 2 sided fine. It feeds 1 sided fine. Was wondering if anyone has seen this on this model and if there is a fix for it. Or should I just order a new door?
  • SCREWTAPE
    East Coast Imaging
    • 3371
    can you upload some photos
    • bobthecopierman
      • Mar 2010
      • 53
      I can upload but wont go back there until tomorrow. I ordered a door.
      • Canuck
        Tech Specialist
        • 1713
        For starters,detach duplex upper section from main door,remove right rear cover,loosen door hinge screws,close the door snug,hold it in proper position,then tighten hinge screws,etc. If another tech had the door off to change the fuser(not necessary),and he just tightened hinge screws without door closed and in position,this could happen. See it on all machines with right doors. Just a quick check
        • SCREWTAPE
          East Coast Imaging
          • 3371
          I'll be looking out.
          • bobthecopierman
            • Mar 2010
            • 53
            Sorry couldnt get pic. Tried loosening hinge and re seating door but didnt work. Put a different door on and the problem was solved.
            Thanks for the help.
            • SCREWTAPE
              East Coast Imaging
              • 3371
              No probs.
              Thanks for posting back.
