My Ir 6570 showing E 804-001.Checked Primary cooling fan,harness,dc power supply fan, and almost all other fans but failed. Need advice from experts
E804-001 in my IR 6570
sigpicAnything can be made to work if you fiddle with it long enough- San Diego Copier Repair.comComment
E804-0001 can be caused if there is a short in the harness for FM2. Disconnect FM2. If FM7 begins to turn and the machine displays a E824 error, then check the FM2 harness located on the Primary Fan Duct.Comment
