problem with canon ir105 paper jam after the fuser unit ani sulotion thank you
I had these two problems in the field, but on Canon iR 7105:
In the first, I replaced the PCB Relay code: FM2-0843-000.
In the second place, I could find the microswitch on the by-pass faulty.
If not implemented, the 24V is not supplied to the relay PCB, causing the failure of the 38V supply to the fixing assy, drum pick up and drive motors.Comment
