Banding on CLC 3220.
  • Ingranaggio_rotto
    • Oct 2010
    • 275
    I have a great problem on Canon CLC 3220: a costant banding to all density....
    I changed the ITB unit, the motor of ITB unit and the relative gears, I cleaned the Laser Unit, I changed the belt that move the drums..... None solution.....
    Tips ?
    Thanks....
  • Fer
    • Nov 2009
    • 267
    Can u please post an example of the printout? I don't realy understand "banding". Are those in feed or cross feed direction, what color? lines or streaks. In print area or white paper background?
    • Ingranaggio_rotto
      • Oct 2010
      • 275
      Good morning....
      For "banding" I intend lines perpendicular at the feed direction, dark lines, visibles in all color, and not on white sheet, with a thickness ranging from 2 and 3 mm, variable distance between them and which are repeated in the print: They are not fixed on the image....
      • Eagle
        • Mar 2010
        • 49
        have u checked the drums? Its could be one of them or even all of them..
        But as FER say "Can u please post an example of the printout" with out these example it will be harder to try to help u out..
        • teckat
          • 16083
          Originally posted by Ingranaggio_rotto
          Good morning....
          inspect the entire HVT Assembly
          • SCREWTAPE
            East Coast Imaging
            • 3396
            Why don't you try PG5 single color test pages to see which color is the problem.
            Since you did not mention anything about replacing drums, have you replaced drums.
            • Ingranaggio_rotto
              • Oct 2010
              • 275
              With the PG type 5 the problem it's visible in each color....
              I changed the drums, but I have not resolve.....
              And even changing the HVT the lines there are.
              • teckat
                • 16083
                Good morning....
                "perpendicular" Banding = Crossfeed = from front of printer to back of printer !!
                1.u do not see any banding on PG5 - SINGLE COLOR v/
                2. is banding on single sheet run/ multi-sheet run/full-color/ b&w/ prints and or copies/ using dadf/ ?????
                what 3220 functions are in use during issue
                3.post samples
                4. have u checked for flat spot on fuser rollers/ ?
                5. Check for proper tension being applied to the ITB from the Secondary Transfer R
                • SCREWTAPE
                  East Coast Imaging
                  • 3396
                  Post a image.
                  The last thing it could be is the main controller.
                  I know that's ironic but it seems like covered most of everything.
                  • Hyksos
                    • Oct 2008
                    • 41
                    3.post samples
                    OMG, I think that's our problem, I just posted a new thread here about vertical line (from back to front of the unit) here: http://www.copytechnet.com/forums/ca...ical-line.html
                    Our fuser is making weird noise like if it's shaking when it roll.... that mean it have a flat spot?? Can it make that kind of artifact? Can it be repaired?
                    And what should we do to prevent flat spot?
                    Thanks for your help
                    • mrfixit51
                      Lead Service Technician
                      • Oct 2008
                      • 1975
                      remove and inspect the ITB assembly...
                      • teckat
                        • 16083
                        Remove fuser-check rotation of unit to look at rollers - may have a flat spot/ gear could be damaged/ bushing on end may have popped out
                        • Ingranaggio_rotto
                          • Oct 2010
                          • 275
                          Yes, for "banding " I intend perpendicular lines, lines from the front of the machine (operator side) at rear of the machine.....
                          There are when the copier prints or copy, in black or colors....
                          When I stop the print operation I find the image on ITB with the problem, before the transfer action on sheet...
                          At soon I will show an image of the problem...
                          • Ingranaggio_rotto
                            • Oct 2010
                            • 275
                            I installed a new ITB unit ! ! !
                            • Irish
                              • 110
                              [IMG]file:///C:/DOCUME%7E1/Owner/LOCALS%7E1/Temp/moz-screenshot.png[/IMG]Check the spring loaded drive gears of the ITB for wear or a broken tooth .. located inside the R/H panel on the rear plate of the machine.. make sure you check the gear it meshes with that stays on the rear plate .. good luck
