Canon C1 Imagepress error codes E000020-0188
  • pictrot
    • Jun 2025
    [Error Code] Canon C1 Imagepress error codes E000020-0188
    this one aparently has the canon engineers guessing
    canon error code E000020-0188
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5006
    Its not that hard.You just need to know how too reed manual.
    First two numbers tells you witch color is the problem,and the second two
    reed by your self.
    • SCREWTAPE
      East Coast Imaging
      • 3396
      If that canon tech is guessing or does not know then he must not be trained. Every canon tech would know that E20's are developer or hopper E-codes. This error has to do with yellow.
      Maybe its time for a developer change.
      • teckat
        • 16083
        Canon engineers guessing ????
        if they are guessing on this code, they belong working in a garage !!!!
        u probably need a drum / dev.change- dirty sensor
        Call for a CANON TRAINED TECH.
        • hinnylass
          • Jan 2012
          • 7
          Re: Canon C1 Imagepress error codes E000020-0188
          Hi, there. I'm new here. But just wondered if you have an update on what this ended up being? I've been having this error code for couple of months off and on and Canon engineer has pretty much done everything he can think of (and other techs) replaced developer, patch sensor etc. But it still keeps coming up. Can do one print and then need shut down.
          Baffled.
          I'm without a printer off and on now since december so tearing hair out.
          I'm not a tech, so please Be Kind.
          • teckat
            • 16083
            Baffled.
            have them replace the Side Driver PCB-FM2-7730-000
            read here------iPRC1-Troubleshooting Procedure for E020 Error Codes.pdf
            • tomasz
              E0020-0188 can be caused by poor connection between Patch sensor and side driver PCB
              Replace "D KIT HARNESS ASSEMBLY" Part number FM2-2615
              Tom
              • hinnylass
                • Jan 2012
                • 7
                Thank you both very much for your prompt replies. Coincidentally, have two Canon engineers here right now and I was a bit nervous about mentioning that I'd been interfering by looking online (some people are a bit funny about it). But both very grateful. One had just said exactly what you suggested before i pipped up...
                Thanks again.
                'Will see if this resolves issue and report back.
                • Alessandro72
                  • Jul 2009
                  • 31
                  Hi hinnylass,
                  I have the same problem, you solve it?
                  thanks
                  https://t.me/pump_upp
                  • Paul 75
                    • Oct 2008
                    • 97
                    I had loads of E020 errors on these machines. After numerous visits it was the patch connection from the drum unit into the connections on the main frame. Apparently they stretch and lose voltage. Try replacing the loom if all else fails !
                    Oh...... I can't copy at the moment then ? !!!!!!
                    • cns9999
                      I know this is an old thread but I'm having the same problem right now, wondering if your problem got fixed and how?
                      • alexsegura27
                        • Mar 2015
                        • 10
                        Re: Canon C1 Imagepress error codes E00006-0002
                        help
                        • teckat
                          • 16083
                          Originally posted by alexsegura27
                          help
                          Error code E006 indicates a problem at the fixing unit connection with the front cover closed.
                          The screw that secures the arm release FL2-2796-000 can loosen causing poor engagement of the fixing/feeder assembly. Make certain that the screw is tight and that the arm release is not deformed.
                          • alexsegura27
                            • Mar 2015
                            • 10
                            Re: Canon C1 Imagepress error codes E000020-0485
                            helppppppppp error e00020-0485
                            • teckat
                              • 16083
                              Check to see if the image patch sensor is reading the patches on the drum.
                              In service mode <Level 2>DISPLAY>DENS>, check P-SENS-P and P-SENS-S for values.
                              If the values are zero, replace the image patch sensor or check that the patch sensor shutter mechanism is working correctly.
                              Also, when was last Drum change_? & Dev change_?
