how to fix wait................ in iRb/w series
  • davidj7
    • 1107
    Hi ,
    As all of you know of the wait .... during booting up.
    How do you fix this . I dont think its a hardware issue with the MFC .
    1) Can this be rectified by a software reload using SST
    2) Is this a boot rom issue?
    I dont mind sending this to the dealer/ service center as I am not gonna try to fix this unless absolutely necessary situations .I do a bit of government contracts and for some of which, time is critical. I cant wait 48 hours for the dealer to fix this and send it back.
    a machine is only as good as your tech : source:screwtape ; the scary one
  • SCREWTAPE
    East Coast Imaging
    • 3396
    What model?
    • teckat
      • 16083
      Originally posted by davidj7
      Hi ,
      what model ??
      place a service call/
      could be anything= bad HDD/POOR CONNECTIONS/POWER/FIRMWARE CRASH
      /STUCK PANEL BUTTON
      • davidj7
        • 1107
        sorry was under lot of pressure whe i typed that
        models:105,105+,7105,7086
        Tried software resinstall using SST no hope. HDD is fine i checked with that of another machines.
        • teckat
          • 16083
          u have that message on all 4 of these models=models:105,105+,7105,7086
          is message "WAIT" or "Waiting to Print"
          do you ever see-"Printer is warming up"
          If the Start key light remains red>
          Check to see if the fixing temperature is increasing in service mode; COPIER>DISPLAY>ANALOG>FIX-C and FIX-E. If the fixing temperature is not increasing, check the duplex connector, both on the duplex unit as well as the rear of the copier. Assure there is no damage, or paper caught in the connectors.
          • davidj7
            • 1107
            just wait at boot up . It dosent finish the booting .
            • teckat
              • 16083
              what is the exact model of the problem printer ????
              could have a bad> Copier Boot ROM
              u could have a low voltage issue on this printer /
              Have u reseated the DIMMS and the Boot on the Main controller
              • D_L_P
                Self Employed
                • Oct 2009
                • 1196
                In my experience if reseating the boot ROM doesn't fix it try replacing the RAM. That is the next most common cause, then I move on the $$$ main control PCB. I think in over 10 years I've replaced less than 5 main controllers and maybe about 10 RAM sticks.
                We ran into this mostly when we tried using non-OEM RAM to save a few $$$.
                • SCREWTAPE
                  East Coast Imaging
                  • 3396
                  Try doing a defrag using 1&9.
                  • SCREWTAPE
                    East Coast Imaging
                    • 3396
                    Start up sequence.
                    <Control Program Area>
                    - Control Program 1 (interval 2)
                    1) The machine checks and initializes the various hardware on the main controller PCB.
                    2) If the previous shut-down sequence was not performed normally, the machine recovers the system files
                    as needed. (In this case, the start-up time tends to be longer than usual.)
                    3) The machine initializes the various program modules.
                    - Control Program 2 (interval 3)
                    1) The machine initializes the various software modules, and checks the configuration of the printer/
                    reader.
                    2) If the printer/reader is found to be normal, the machine ends the start-up sequence; otherwise, it will
                    indicate E732/E733.
                    Where does it stop?
                    • ymmtech
                      • Jun 2009
                      • 191
                      Wait at interval 3 ? Try restore RAM data.
                      • teckat
                        • 16083
                        Waiting~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~ ?
                        • davidj7
                          • 1107
                          [QUOTE=teckat;176192]what is the exact model of the problem printer ????
                          This is the models I use for large volume and I am concerned for the issue in these printers only . Rest I will send to dealer for service.
                          Presently its is 7105.
                          • davidj7
                            • 1107
                            thanks DLP i will buy and keep a few boot rom and couple of RAM's
                            • davidj7
                              • 1107
                              screwtape : the progress bar reaches the end and then stops. like in the figure at the end of section 3.
