Power On Jam err
**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
I hate that code/
Check the Inner delivery sensor
PS15
position
u can scuff up underside of the transport belts & black drive roller with a green pad
Good Read PDF below on 010D
TP08 310c[1].pdf**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Check this also
Product : imagePRESS C1 Title : 010D Jam Problem :
Intermittent 010D jam code when feeding LTR size media. This jam can occur during mono or full color copying or printing.
Solution :
Replaced the Mount Separation Drive Assembly: FM2-7983-000, this drives the lower fixing belt assembly.
Before removing the mount assembly be sure to scribe the two mounting brackets.
