Hi Guys, I have this problem. A IR9070 with error code E820-000. I replaced the drum fam, and the dc controler, and the problem persist. I checked the wire with malfunction, but it's normal. Any idea?
IR9070 error code E820-000
Tags: act, code, connections, controler, drum, error, error code, ir9070, malfunction, replaced, wire
I think you must have a contact of fan wires on copier body.
I know is too hard,but you must replace fan wire."Who loves the roses,must also bear thumbs" -
**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
If the fan doesnt rotate in 5 seconds when drum starts to rotate,copier shows an error code."Who loves the roses,must also bear thumbs"Comment
