Canon MF8180c noise
  • landspeeder
    • Feb 2010
    • 355
    Canon MF8180c noise
    It shows the error code E021..which is a dev mtr problem......the printer is noisy and quite jammed ...could it be the carosel, can't spell that one, maybe bearing at one end...I dont know...any ideas?
    You never realize how cheap a professional is until after you let an amateur do it.... and
    if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!!
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Is it a motor noise or noise when developers running around.
    • landspeeder
      • Feb 2010
      • 355
      a motor jammed noise as if it was trying to turn the dev....noisy but not snapping
      • teckat
        • 16083
        think that E021 is the Carousel error/ check for blockage
        • landspeeder
          • Feb 2010
          • 355
          when I put a spring hook and lifted the right side of the Carousel it moved up a 1/4" at least if not a bit more and on the left only 1/8" ...to me it could be the brg support worn out and that could be $$$$$ p and L...how much do you think it would cost?
          • landspeeder
            • Feb 2010
            • 355
            any one have a part number for the Carousel so I can quote the person
            • teckat
              • 16083
              think that is the part #
              Look Here/ HP makes that part >fits in a number of HP & Canon
              HP RG5-7587-090CN Carousel (Rotary) Assembly - INCLUDES The Carousel a
              is this what u want ?????
              • landspeeder
                • Feb 2010
                • 355
                Thats perfect! Thankyou...looks like up here the dealer cost is around $115., not bad considering what you get.....
                • landspeeder
                  • Feb 2010
                  • 355
                  So I got the part, H/P part number, and put it in yesterday...yes it looks the same but the tab slots on the right side are moved so the toners do not fit in. We fixed that issue buy cutting the tab's off but the machine doesnt recognize the cartridges are installed...so the bottom line is the part will NOT interchange..I'm stuck and I'm going to try and make 2 into 1..if anybody has a easier idea let me know asap....to take this all part again...UGH
                  • teckat
                    • 16083
                    I would contact HP, they have on their site that , part will function in Canon MF8180
                    what is the part number that was sent to you ??
                    http://www.precisionroller.com/drive...ils_64986.html
                    • landspeeder
                      • Feb 2010
                      • 355
                      made two into one, retimed it and it works.....lot of work....two things that are different 1/ slots for toner tabs are in a different spot and 2/ sensor that contacts the chip on the toner is moved enough so it wont contact the cartridges..no reset... thanks for the help as I still needed that part to get this machine goin....it belongs to the police!!
                      • teckat
                        • 16083
                        Thanks , & good luck
                        • Discountcopiers
                          • Jun 2011
                          • 52
                          Re: Canon MF8180c noise
                          do you have a service manual for this one? I am having a problem finding one for a reasonable price. thanx arnie
                          • JustManuals
                            • Jan 2006
                            • 9838
                            What are you calling a reasonable price? I have it for $14.99.
                            • landspeeder
                              • Feb 2010
                              • 355
                              Yes ...his selection/pricing for the manuals is very good. I buy from him and have no complaints...and if you cant find what you need he will .....on a score of "0 to 10"................................. "10"
