C3200 - C3220 - Wake up
  • kuby
    • Oct 2007
    • 1373
    Is there a setting where you can have the machine "Wake up" in the morning so it will be ready when the customer gets to work in the morning? Customer is starting to get mad because they have to wait for it to go through its warm up to print in the morning.
  • teckat
    • 16083
    Tell customer this Printer is not a Coffee Pot/
    You have three Power Modes>
    power save mode, low power mode, or sleep mode
    Under Common Settings
    Change power save mode to > immediate recovery
    when customer walks in and hits the Power Saver Key it will do an "immediate recovery"
    Next -I would turn off the <SLEEP> setting
    Used to turn auto sleep function ON/OFF.
    Setting 0: OFF
    You can then look at the weekly timer 00:00 to 23:59 (1-min increments)
    I never used this before-
    Power-Save Mode
    Shift: A shift is made in response to the passage of time (auto sleep shift time)
    specified in user mode or in response to a press on the control panel
    software power switch.
    Description: In sleep mode 1 (relatively higher power consumption), the fixing assembly
    is totally deprived of power. The DC controller PCB, however,
    remains supplied with power.
    In sleep mode 2 (relatively lower power consumption), on the other
    hand, the printer unit (including the fixing assembly) remains OFF; the
    main controller PCB is supplied with all-night power as indicated in the
    table
    Controller
    +3.3 VAN -CPU,
    Main memory
    +12 VAN - Controller cooling fan
    FAX
    +5 VAN fax arrival detection
    AC OFF Mode
    AC OFF mode occurs when the main power switch is turned off, i.e., all parts of the machine
    is deprived of power.
