My Canon C3220 keeps giving me an error code of E000751-1304
  • pnse
    • May 2025
    [Error Code] My Canon C3220 keeps giving me an error code of E000751-1304
    I am printing front and back copies and then the machine stops with the error code E000751-1304. I remove paper from inside machine that stopped processing when the error occured, turn it off and then able to run a few more copies. What does this code mean?
  • tinnyjay
    • Oct 2009
    • 655
    This is an error code inspected by Canon after they made copier.
    The error code means the internal memory of drum unit will not dissapeare even if you change black drum.
    You must change PCB.
    bye
    "Who loves the roses,must also bear thumbs"
    • pnse
      What is PCB?
        • 16083
        E751 The connection of the drum unit /toner container is faulty.
        The mark x indicates color [Y=1, M=2, C=3, K=4].
        130x Built-in memory writing error in the toner container (When the number of retry exceeds
        the specified value).
        Memory Pcb.
        FG3-2345-000
        connects to toner drive assembly
        MACHINE REAR PLATE
        Memory PCB is not part of the drum unit.
        000x The connection of the drum unit (at the printer side) is faulty.
        100x The connection of the toner container (at the printer side) is faulty.
        010x Built-in memory writing error in the drum unit.
        110x Built-in memory writing error in the toner container.
        020x Built-in memory data error in the drum unit.
        120x Built-in memory data error in the toner container.
        030x Built-in memory writing error in the drum unit (When the number of retry exceeds the
        specified value)
        • sgcopiertech
          Re: My Canon C3220 keeps giving me an error code of E000751-1304
          @Teckat:
          does it means that any e751 error is directly related to the memory pcb (FG3-2345-000) regardless of the sub-code?
          030x Built-in memory writing error in the drum unit (When the number of retry exceeds the specified value)
          so it's not actually the drum unit?
          a new lot of 3220 came and we've found out that most of them have e751 errors on the error history.
            • 16083
            depends on the SUB-CODES
            if u replace the Drum or Toner cartridge in question
            The mark x indicates color [Y=1, M=2, C=3, K=4] ,
            and the error- e751 will not clear ,
            u may have to replace the
            Memory Pcb. FG3-2345-000
