Canon MF4140-BLACK HORIZONTAL LINES
  • media4u
    • 20
    I need Canon i-SENSYS MF-4140 Firmware, please media4u@net.hr.
  • teckat
    • 16083
    i-SENSYS MF4140
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      What kind of lines?Put some pictures.
      • media4u
        • 20
        • zoraldinho
          • Mar 2008
          • 5015
          You cant fix this with firmware.Its look like scaner or PCB issue.
          • teckat
            • 16083
            black lines on the printout..no toner or scanner[ATTACH=CONFIG]7209[/ATTACH]
            what do u mean -no toner or scanner ??
            do u have the print server AXIS 1650
            server connected to it
            is that a network print or a glass copy
            • media4u
              • 20
              scanner is fine, there is only a problem with printing, each other is in error
              • teckat
                • 16083
                YOU did not answer the question !!!!!!!!!!!!
                if u place and print from a document on the glass- do u have a copy quality issue ?
                the print issue example u posted- is that from a glass copy or was is sent from a PC/Laptop directly to MF4140
                • rorro
                  You must have tried the obvious? Drum/cartridge/hvt transfer? Did anything weird happen in this office preceding the problem?
                  • media4u
                    • 20
                    Everything is wrong with the scanner, transfer corona and catridge ..
                    • teckat
                      • 16083
                      • zoraldinho
                        • Mar 2008
                        • 5015
                        You sound like angry??.
                        • media4u
                          • 20
                          I need to firmware update for mf4140.Please send me media4u@net.hr.
