IR4570 Vertical Path Rollers and Registration Roller
  • jo3y
    • Oct 2010
    • 12
    Hi! I am admittently new to all of this, and I have a question regarding vertical path rollers. I am have a paper jam issue, but the paper doesn't jam, it just stops feeding randomly. Sometimes it makes it halfway up the vertical path, sometimes 1.4 the way ...
    I purchased and replaced the 3 rollers that pickup the paper(for both cassettes), and I am now on to the registration soft roller and the vertical path rollers.
    My question is, is there a thread that shows how to do this? I know I have to remove the assembly, but don't want to mess anything up.
    My second issue is the gears that are on the shafts themselves, I don't know how to remove them and I don't want to break those either.
    Would anyone familiar with this process help a newbie out?
    Thanks in advance!
  • charm5496
    • 2387
    before you go and tackle that registration roller which isn't easy I would make sure your machine has the update door mod for the cassettes. This is the smaller lower door just underneath the large door.
    FM3-1296-000 and FM3-1297-000. If your current door has any amount of foam on it then it is the older style and the new inner guide would have a leaf spring on it. The old one just had the black guide and white pressure rollers. If you search this forum there is probably some additional information in here with pictures possibly.
    • costd
      • Jan 2008
      • 409
      I recommend you hire a trained tech that knows how to display the jam code and then replace/repair the right part. Jusr replacing parts because it worked for someone else may not solved your problem. That said, you may be looking in the right area. This series had an issue with the vertical feed rollers and the door. If you insist on DIY, then you need to obtain a service and also a parts manual. The manual will tell you how to remove the paper feed unit to get at the vertical feed roller. Once the roller is out, removing the gear is easy - just a plastic retainer.
      Parts may be a little hard to find as it appears you may not be working for a dealer and will just have to try the internet.
      • jo3y
        • Oct 2010
        • 12
        Thanks!
        Thanks guys, this forum rocks. As for my situation:
        I am under the gun, the people hired me and don't want to use a Canon technician.
        In this picture ...
        How do I get this thing off?
        • charm5496
          • 2387
          that is your registration roller with a pin you have to knock out in order to remove it. I was refering to the right lower door and the inner guide which are a major issue with this model causing the jams in that area. Here is what the door and the inner guide looks like. You can get them from precission roller if you need more info.
          • jo3y
            • Oct 2010
            • 12
            Thanks again for the reply. Yeah I had already removed the registration roller, and was covering all rollers to try and resolve the issue. I have a new vertical roller shaft, registration soft roller shaft, and the 6 rollers in the 2 pickup areas.
            One thing I noticed was when I apply pressure to the door during a feed, it works. When I do not apply pressure, it does not work at all, just stops mid path. Sometimes it gets further than other times. This is why I was replacing all rollers dealing with vertical travel and pickup.
            Thank you very much once again, this is a huge help!
              • 23007
              The door is the usual solution to this problem. Since the door does not press the vertical guide hard enough, there is insufficient pressure on the idler rollers to drive the paper upward. I think I'm the fourth person to suggest this to you. Look at the right side doors.
              • jo3y
                • Oct 2010
                • 12
                Thank you all, I ordered the two parts you suggested
                • charm5496
                  • 2387
                  not a problem. godd luck!!!
                  • Brian8506
                    • 1664
                    My 2 cents will match the others. Replace the door and guide. I do it on all my copiers that use that style. You diagnosed it for us when you said it works when you apply pressure on the door. I'd bet the farm that the door and guide solve your problem. Your farm, not mine.
                    • Canuck
                      Tech Specialist
                      • 1713
                      Make sure that the vertical rollers have gray rubber,not black also,and that the pre-reg actuator is not worn down.
                      • jo3y
                        • Oct 2010
                        • 12
                        I received the parts but am nervous about replacing them (the two assemblies). Does anyone have a diagram by chance that will show the order of things to remove?
                        • teckat
                          • 16083
                          need a book ???
                          • jo3y
                            • Oct 2010
                            • 12
                            Originally posted by teckat
                            need a book ???
                            If it explains how to replace the two assemblies that would be nice. The manuals I have for the copier don't even have a parts list.
                            • charm5496
                              • 2387
                              The outer door comes off very easily. Open the large right door. The open the door you are replacing. Push in on the white tab that will towards the front of the machine and it will drop down further and slide out toward you from its holders.
                              The black guide is next. You may want to remove the grey covers on either side since you have never done this before, but it to will drop down towards you and slide out of its holders. The guide it a little more stubborn than the door is because the other guide from the cassette can get in your way. Reassemble with the new parts...again putting the black guide in can be tricky so take your time and make sure you ground the blue wire to the frame.
                              If you can replace the vertical path and registration rollers on this machine then I am pretty sure you can tackle this as well.
