Canon GP405 Error E220
  • mitsubee
    • 176
    Dear All ,
    I have a GP405 that pop up an E220 , can anyone help me with this problem?
    Thanks first.
    Calvin
    P/S : i have change the IP Board but it still with this E220
  • T6895
    • Jan 2007
    • 33
    I'm not trained on that particular model but a 220 code is usually an exposer lamp or exp. heater
    • Don DeBey
      E220
      That is a scan lamp error on all Canons that I know of. Check continuity on the lamp. Then check the in line fuse. It could also have a shorted scan cable.
      Hope that helps.
      • mitsubee
        • 176
        Thanks T6895 & Don,
        I'll try to double check the scanning area
        • toantam
          • 63
          Originally posted by mitsubee
          Dear All ,
          Thanks first.
          Calvin
          You have to check ccd cable good or not; or you try to change CCD unit
            • 23008
            Technically E220 is a lamp intensity error. The lamp intensity can be low (or high, but usually low) for many reasons:
            1) lamp lights slowly, late, dimly, or flickers: could be a bad lamp, bad inverter, bad lamp harness, bad lamp heater, or just really cold in the room (fluorescent lamps don't light very quickly or very brightly in the cold).
            2) perception that the lamp is not bright enough: CCD, CCD cable, Image processing board.
            One is much more likely, and much less expensive than Two.
            • toantam
              • 63
              I have an idea for E220
              You can check CCD cable
              Scanning lamp sensor ( it's connect to scanning lamp )
              I hope you can solve your problem
              • Don DeBey
                Check continuity on scan cable
                If you place your leads where power plugs into scan cable throught he back of the frame and drive the scanner by hand. I'll bet there is a short. These old canons do it all the time. There would be continuity at home position, but as the scanner moves a crack opens up in the cable breaking contact. I know I sound like a broken record, but I have changed many of these cables over tne years. Good Luck, Don
                • salmi
                  • 11
                  try to change the thermistors in the heater bloc
                  i know it seems to be illogical with this error code e220
                  but i made the experiance with np6220 i changed all but the error e220 still appears time to time
                  but when i changed the heater thermistors the problem is fixed. all you have is to try . bye !
                  • rambo40
                    • Oct 2007
                    • 21
                    hI mate,
                    You most likely have a fluoro lamp problem.Check the ends of the fluoro lamp if it is blackened then it is gone.The green fluoro lamp is used in this model for scanning.
                    • JustManuals
                      • Jan 2006
                      • 9838
                      I have a free file of Ricoh-Lanier error codes posted on my site at:
                      http://www.manuals4you.com/free
                      Paul@justmanuals.com
                      • AIT MAMEUR
                        • Jun 2008
                        • 59
                        • mujibur
                          • 53
                          gp405 e220
                          The scanning lamp turns on abnormally.
                          you chek scanning lamp has a fault.
                          intensity sensor has a fault.
                          CCD PCB has a fault.
                          composite power supply PCB has
                          a fault.
                          DC controller PCB has a fault
                          • mujibur
                            • 53
                            gp405 e220
                            sec when it should remain on
                            • petrus
                              • 155
                              You also need to check the *White plate* undernet the metal plate at lefthand side of the scanning compartment.it must be clean.
                              also try to runs the CCD auto adjustment in *2&8* /function
                              this error code refer major on Light intensity low/light intensity not detected by the ccd.
                              simple words is the scanning lamp seems not turns on.
                              Normally For me after runs the ccd auto adjustment its get rid.
