IR3570 no power according to customer
  • axyun
    • Aug 2007
    • 1323
    Customer called saying no power on IR3570. I asked if no display and no lights etc. Customer said nothing at all. Just want to know if there are any known common power issues with this series before going.
    i mean it could be a circuit breaker tripped or power cord connection is damaged etc. but just thought I would check with Canon experts first. Normally when an door interlock is a problem tou get an open door message on most machines though I thought I had an interlock problem on an IR C3100 that showed no evidence power. Of course it could be I'm having a senior moment Any advice is very mush appreciated unless it's related to retirement. Thanks Frank/ActionPhotocopy
  • teckat
    • 16083
    tell customer to plug something in outlet to check
    even when u have a internal power issue ,usually the low voltage control panel green light will come on ?
      • 23010
      Make sure that your surge suppressor hasn't taken a hit. I've either repaired or replaced surge suppressors for 'No Power' situations at least a dozen times. =^..^=
      • charm5496
        • 2387
        wonder if the breaker on the back of the machine is thrown?
        • axyun
          • Aug 2007
          • 1323
          Thanks for the tips guys. I hope you have a Great Thanksgiving weekend. Frank
