Can I print on 110lbs paper if the highest weight setting in paper types is 80 lbs?
  • aab1
    End User
    • Oct 2010
    • 305
    I'd like to laser print on 110 lbs card stock but the heaviest weight in my copier's (MF8350Cdn) settings is 80 lbs. Is there any risk of damaging the machine if I use 110 lbs paper in the multi-purpose tray? My inkjet can handle 110 lbs but I'd really prefer to have this job laser printed if I can do it without breaking my laser copier.
  • JustManuals
    • Jan 2006
    • 9838
    The asshole is back with his stupid questions. Must be a full moon.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      • aab1
        End User
        • Oct 2010
        • 305
        Originally posted by zoraldinho
        Try with ceramic tile.If you can do it use 110 lbs paper.[ATTACH=CONFIG]7291[/ATTACH]
        What a coincidence, we are actually renovating and have several ceramic tile samples. Unfortunately the smallest is 12" long so it won't fit.
          • 23009
          Do we have to commend you for using inkjet printing? I'll hazard a serious answer if you can manage a few posts without bragging or praise for your financial prowess, or your fanciful modified inkjet printer. =^..^=
            • 23009
            Firstly, "cardstock" is not a technical designation of any specific type of paper.
            110# Bond is ~400 grams/meter2
            110# Offset is 165.55 g/m2
            110# Cover is 308 g/m2
            110# Tag is 176.83 g/m2
            110# Index is 199.41 g/m2
            So before we even commence this discussion we need to know 110# what?
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
              It is "Turkey" Day, isn't it?
              • KenB
                Geek Extraordinaire
                • Dec 2007
                • 3944
                A 110# blond would be nice!
                • aab1
                  End User
                  • Oct 2010
                  • 305
                  The Staples website gives practically no details, I'll have to see the package at the store and see if it says more:
                  STAPLES | BUREAU EN GROS
                  • mrwho
                    Major Asshole!
                    • 4299
                    So, he's not only cheap when aquiring equipment, he's also cheap when buying supplies.
                    I'm not surprised.
                    Mascan42
                    Ibid
                    • aab1
                      End User
                      • Oct 2010
                      • 305
                      I'm not surprised.
                      How am I cheap when buying supplies? I asked if this paper would work in my laser copier, what's cheap about that? Or are you referring to the paper I posted? I don't know any other place that sells 110lbs paper if that's what you mean and I only need a few sheets of it anyway.
                      • mrwho
                        Major Asshole!
                        • 4299
                        Staples paper without any description.
                        Mascan42
                        Ibid
                        • aab1
                          End User
                          • Oct 2010
                          • 305
                          OK I have the pack of paper now, it is 199g/m2, would that be ok in my laser copier?
                          • aab1
                            End User
                            • Oct 2010
                            • 305
                            By the way, shouldn't the lbs of the paper be relative to the g/m2? How can you have different papers with the same lbs rating but different g/m2 ratings? Isn't that like saying a 150 lbs person could weigh 50kg, 75kg or 100 kg?
                            • mrwho
                              Major Asshole!
                              • 4299
                              Explanation
                              Mascan42
                              Ibid
