Can I retrieve a copied document on a Canon 5070?
  • jsw2k
    • Oct 2008
    • 95
    I have a client who needs to retrieve a document from their i/R-5070 that was copied yesterday. They don't use the document server feature and they don't even have the unit connected to a network.
    Is this possible and, if so, how would one go about it?
    Thanks!!
  • Fer
    • Nov 2009
    • 267
    How big was the document? If it was big enough to fill all the ram, it will be stored on the harddisk also. U can remove the disk and scan for image files and try to reprint them.
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      No. It is impossible - period.
      • jsw2k
        • Oct 2008
        • 95
        I don't think it was big enough to fill the ram.
        • SCREWTAPE
          East Coast Imaging
          • 3396
          The ? I have is... Where is the document. Was it stored in the mailbox?
          • jsw2k
            • Oct 2008
            • 95
            No...it was just a "regular" copy. Apparently, there is a dispute and the client needs the copy to prove his case, but failed to actually save a hard copy before giving the original back to the other party.
            • teckat
              • 16083
              not saved=out of luck
              • jsw2k
                • Oct 2008
                • 95
                I was afraid of that, but just wanted some confirmation from people who KWTFTTA.
                Big Thanks!!
                • SCREWTAPE
                  East Coast Imaging
                  • 3396
                  Its stored on the hard drive. But your getting it unless you have proper software.
                  • blazebusiness
                    SanDiegoCopierRepair.com
                    • 1257
                    I think he's out of luck. I agree that it was stored on the hard drive but what software could be used to retrieve it Screwtape? I'm unaware of any software or utility that might be used to do this.
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3944
                      I thought this topic was covered (seemingly endlessly) a few months ago with all the uproar about HDD security.
