ir2870 - print kit install
  • kuby
    • Oct 2007
    • 1409
    ir2870 - print kit
    Have installed a print kit for a ir2870 and it will not see the network at all. Does the system software have to be a certain version? Have the right IP address, tried pinging the gateway - nothing. Did a P-Print and it sees the N-Bootrom. What am I missing?
  • teckat
    • 16083
    Originally posted by kuby
    ir2870 - print kit
    service mode
    COPIER>OPTION>INT-FACE>IMG-CONT> set to "0"
    Multi-PDL Printer Kit-E1
    PDL KIT E1.pdf
    • kuby
      • Oct 2007
      • 1409
      Yes it is set to "0". Does this have to have the Universal Send Kit - B1 to turn on the nic card? Never had to install a print kit in one of these, always came with it.
      • mrfixit51
        Lead Service Technician
        • Oct 2008
        • 1975
        Checking the Installation
        Make the following selections, and check the state of the following bits: COPIER > ACC-STS > PDL-FNC1.
        111x xxxx xxxx xxxx (0: OFF; 1: ON)
        In the case of the PDL-FNC1, bits 31 through bits 16 are indicated. Be sure that the following bits are '1': 31, 30, 29.
        • teckat
          • 16083
          READ THE PDF I POSTED/ has all the settings needed
          • kuby
            • Oct 2007
            • 1409
            According to the P-Print, COPIER > ACC-STS > PDL-FNC1 is set to 1111 0000 0010 0000.
            Do I need to try a MMI clear?
            • mrfixit51
              • Oct 2008
              • 1975
              Have you tried to ping it via laptop and crossover cable, thus eliminating the customers network from your diagnostic process? Was this ever hooked up previously to the network, to say, manage the copier/fax operation thru RUI? The Ethernet port on the main controller might simply be fubar.
              • kuby
                • Oct 2007
                • 1409
                No I am going back today to try that. No it was never hooked up, it did not have a print kit installed.
                • teckat
                  • 16083
                  where did u purchase this KIT ? online or from Canon USA ??
                  • kuby
                    • Oct 2007
                    • 1409
                    I purchased it on line, but I also took one from a working copier, same results. But the kit works in the other copier.
                    • teckat
                      • 16083
                      is the green link light on ?
                      • kuby
                        • Oct 2007
                        • 1409
                        No, the green light does not come on the copier.
                        • charm5496
                          • 2387
                          I would try pinging the copier with a crossover cable. If those two talk then you have a cable issue somewhere in the customers network. If they do not talk then you have a main controller issue. Unfortunatly the NIC is built into the main controller on all these newer models.
