Canon 3240 "Insert toner"
  • Jeff M.
    • Dec 2010
    • 127
    Display reads:"Toner is not set. Insert toner". The toner IS in, tried a new OEM cartridge, same result with old and new cartridge. Any ideas? Thanks.... Jeff M.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    If you are a tech you can open the machine and check toner lever lock.Read this PDF below.
    ir4570-102.pdf
    ir4570-105.pdf
    • teckat
      • 16083
      what is a 3240 ??
      is it the MF3240 ?
      MF3240
      is this a non=oem cartridge ? if so
      Check if metal pin is touching the inside sensor.
      U may need to pull out out the metal part so it can touch the sensor, the printer will then detect the toner.
      • zoraldinho
        • Mar 2008
        • 5018
        [ATTACH]7501[/ATTACH]
        [ATTACH]7502[/ATTACH]
        Canon MF 3240?? WTF. It's embarrassing.
        • Jeff M.
          • Dec 2010
          • 127
          Yes, I am a tech, yes it is an MF 3240, and yes, it is embarrassing!. Spent enough time with this POS. Not worth it. Was hoping it might be a quick fix. Thanks for your responses. Regards.... Jeff M.
