ir3300N scan
  • jiongpao
    • May 2009
    • 413
    ir3300N scan
    We got a machine ir3300N but without the network card device and currently connecting to computer print using bi-directional parallel cable running fine. Does it support scan function using the cable? Wat kind of software or driver should i install?
  • mrfixit51
    Lead Service Technician
    • Oct 2008
    • 1975
    To the best of my knowledge, scan only occurs thru the networked interface, not the parallel port. Scangear does not support the parallel port, and there are no twain drivers for 3300's.
    • jiongpao
      • May 2009
      • 413
      Actually theres a message show "check network connection". Tats mean we should change the network card?
      • sufie
        • Sep 2009
        • 10
        "check network connection " thats mean if you using the network conection,you must check like ip addres,subnet mask,gateaway.thats must be same with network on your place.
        IR3300 only can scan using network interface,than instal network scan gear..
        • mrfixit51
          • Oct 2008
          • 1975
          The only two ways to clear the connection message is, since your original post says the network card is missing, put a network card in it, and get it onto a live network,, or, replace the bootrom to a copier model, and reload the copier version system software to replace the networked version of system software.
          • jiongpao
            • May 2009
            • 413
            mrfixit i need to correct myself, it does attaching the network card and it show "check network connection" and i thought from the beginning the network card is condemn and i just let it be, thats why i use parallel cable to connect computer. You mean when the message show so, it doesnt mean that the network card condemn? Or should i try to reload the firmware with N version again since we bought from other country?
            • mrfixit51
              • Oct 2008
              • 1975
              For clarification, "Check Network Connection" is presented when the copier cannot see a valid network connection, and the copier only checks the ethernet port. It only checks it one time during startup,, so if you make network IP changes, restarting the copier is necessary. The best way to check the port is to set up an IP on the copier, restart the copier, hook laptop\PC to the copier via a crossover cable, and see if the copier can be PINGed. Wait a couple minutes for the copier network card to become active after turning the copier on, it is not instantaneous.
              • Canuck
                Tech Specialist
                • 1713
                If IP addresses are wrong, it won't tell you to check network connection as previously stated. It will tell you to check TCP/IP. As stated, check network connection means it doesn't see network....just fyi
