Canon IR5075 ADF Problem - Jam Code 0094
  • pcernicky
    • Feb 2010
    • 66
    Copier has a Jam code 0094,
    When the copier is turned on without using adf everything is ok, but as soon as I put a sheet of paper to ADF and hit start, copier shows paper jam. When you turn of and on jam is gone.
    I clean all sensors and reflective pads.
    Please help.
    Thank you all.
  • mrfixit51
    Lead Service Technician
    • Oct 2008
    • 1975
    0094 Jam Code: Spring comes off actuator of No.2 read sensor found in DADF-S1 (Rank A)
    [ Case in the field ]
    Description
    Since the spring came off the actuator of No.2 read sensor (PI11), the jam code "0094" persisted.
    - 0094 Jam Code: Power-on jam in the document feeder side. This machine is programmed to display this jam code when the document feeder starts picking up the first original, not immediate after switch-on of this machine.
    Field Remedy
    1. Check if paper gets jammed at a sensor; if so, remove the paper.
    2. Clean all sensors and then execute the following service mode: Service mode > FEEDER > SENS-INT.
    3. If the symptom still occurs, check if the spring has come off the actuator of No.2 read sensor (PI11); if so, attach it again.
    0094 Jam Code and message "Open the feeder cover." occur when using ADF
    [ Inspected by Canon Inc. ]
    Description
    Since the jam code "0094" and the message "Open the feeder cover" appeared when using the ADF, the reader controller data was entered again.
    - 0094 Jam Code can be displayed when the cover open/close detecting sensor of the ADF detects an unexpected opening of the cover.
    Cause
    Since the reader controller data was corrupted, 0094 jam, which was not indicated under normal condition, was indicated.
    Field Remedy
    1. In service mode > COPIER > Function > CLEAR > R-CON, select the OK key and turn the main power switch OFF/ON to clear the data of the reader controller PCB.
    2. Enter the values of the service label (affixed to the backside of the reader front cover) into service modes.
    2-1. Image read start position adjustment (X direction in fixed reading mode)
    Service mode > COPIER > Adjust > ADJ-XY >ADJ-X
    2-2. Image read start position adjustment (Y direction in fixed reading mode)
    Service mode > COPIER > Adjust > ADJ-XY >ADJ-Y
    2-3. Shading position adjustment (in fixed reading mode)
    Service mode > COPIER > Adjust > ADJ-XY > ADJ-S
    2-4. Feeder mode main scanning position adjustment
    Service mode > COPIER > Adjust > ADJ-XY > ADJ-Y-DF
    2-5. ADF stream reading CCD reading position adjustment
    Service mode > COPIER > Adjust > ADJ-XY > STRD-POS
    2-6. Density manipulating value adjustment
    Service mode > COPIER > Adjust > CCD > DFCH-G2
    Service mode > COPIER > Adjust > CCD > DFCH-G10
    (After entering the values to these modes, be sure to execute service mode > COPIER > Function > DF-LNR.)
    2-7. Original stop position adjustment (X direction in stream reading mode)
    Service mode > FEEDER > Adjust > DOCST
    2-8. Original feed speed (magnification) adjustment
    Service mode > FEEDER > Adjust > LA-SPEED
    3. Execute the following adjustments.
    3-1. ADF sensor sensitivity adjustment
    Service mode > FEEDER > Function > SENS-INT
    3-2. Tray width adjustment
    Service mode > FEEDER > Function > TRY-A4
    Service mode > FEEDER > Function > TRY-A5R
    Service mode > FEEDER > Function > TRY-LTR
    Service mode > FEEDER > Function > TRY-LTRR
    3-3. White plate data adjustment
    Service mode > COPIER > Function > CCD > CCD-ADJ
    3-4. ADF white level adjustment
    Service mode > COPIER > Function > CCD > DF-WLVL1
    Service mode > COPIER > Function > CCD > DF-WLVL2
    Note: The white plate data adjustment must be performed prior to the ADF white level adjustment.
    • pcernicky
      • Feb 2010
      • 66
      So you think it's not the sensor PCb's?
      • charm5496
        • 2387
        probably PCB 2 & PCB 4
        • teckat
          • 16083
          Please help.
          Thank you all.
          Additional Info to add on>>
          imageRUNNER 5050 / 5055 / 5065 / 5070 / 5075 / 5570 / 6570
          imageRUNNER C5058 / C5068 / C5800 / C5870 / C6800 / C6870
          DADF-M1
          DADF-S1
          0094 Jam Code
          The document feeder is generating a 0094 jam code that will not clear until the machine is power cycled. A 0094 jam code can be generated by any paper path sensor in the document feeder.
          Returning the prism for PI7(DADF M1) / PCB2(DADF S1) to its proper position, resolved this issue.
          See photo below for location of sensor prism.
          • teckat
            • 16083
            more add on>>>
            April 11, 2008
            imageRUNNER 5050 / 5055 / 5065 / 5075
            DADF S1
            0094 Jam Code
            A 0094 jam code can be generated by any paper path sensor in the document feeder. PI1, PI11, PI12, PCB2, PCB3 and PCB4 can cause this type of jam.
            In this instance, a foreign object was found interfering with the flag actuator operation of PI11.
            The picture below shows the location of PI11.
            The machine displays a 0094 jam code when the DADF is used. At the start of operation the presence of an original has been detected by a sensor in the paper path. The sensors that generate the code are PCB2 the Post separation sensor pcb, PCB3 the Read sensor, PCB4 the Delivery/reversing sensor pcb.
            All three sensors have the same part number FM2-1022-000.
            • Fer
              • Nov 2009
              • 267
              I bet on SENS-INT
              • pcernicky
                • Feb 2010
                • 66
                Originally posted by Fer
                I bet on SENS-INT
                Yes. That did it.
                Thank you very much.
                • bbkyle14
                  Re: Canon IR5075 ADF Problem - Jam Code 0094
                  please help me to solve my problem.... i have canon ir 7105 machine.... its always jam when i start to use adf... jamming code 0094..... guys i really need your help.... thank you
                  • mrfixit51
                    • Oct 2008
                    • 1975
                    Just fought this a while back on an iRA6055. The registration sensor on that beasty uses a prismatic reflector, mine had been knocked out of place. Symptoms were exactly as you described.
                    • teckat
                      • 16083
                      imageRUNNER 7105
                      The quickest way to troubleshoot a 0094 is to use the FEEDER IO section found in service mode. COPIER>IO>FEEDER.
                      The sensors listed that can cause a 0094 jam are PI4 / PI12 / PI13 / S1 / S2 / S3 / S4 / S5 / S9.
                      Each of these sensors should be 0 no paper and 1 when paper is detected.
                      Use the IO mode to detect faulty sensor reading.
                      COPIER>IO>FEEDER.
                      P001 bit 1 = S2
                      P004 bit 7 = S9
                      P006 bit 4 = S4 P006 bit 7 = S3
                      P007 bit 1 = PI4 P007 bit 4 = S5 P007 bit 6 = S1
                      P008 bit 6 = PI13 P008 bit 7 = PI12
                      imageRUNNER 7105 / 7095
                      DADF-Q1
                      DADF-Q1 0094 Jam Code
                      Jam code 0094 is logged when the start button is pressed and using the DADF-Q1.
                      The original does not feed and power cycling the copier is the only way to reset the jam.
                      Clean paper dust from the DADF sensors and perform the sensor adjustment on page 4-22 to 4-23 of the DADF-Q1 Service Manual.
                      The following image shows the procedure from the Service Manual highlighted in red.
                      • saidone
                        • Mar 2012
                        • 12
                        IR 5075 machine, ADF problem, paper jam after replace inner roller and all rubber roller. It run several sheets of paper and jammed, so on and so on. How to solve it?
                        THX.
                        • teckat
                          • 16083
                          THX.
                          Codes
                          Paper size
                          Copies or prints or on both
                          • dan7777
                            • Dec 2012
                            • 680
                            Please help.
                            Thank you all.
                            0094 in adf is a hard one. It means one of the sensors is blocked or failed when machine turned on. Some of them are hidden. I do not have but one or two of those models any more so I am used to the advanced models. Have had to swap out two doc feeders for this code. You basically have to check every sensor.
                            • Raoufselwaness
                              Expert
                              • Nov 2008
                              • 75
                              hi;
                              i have ir7105 at customer site, soddenly stopped printing, but i can ping it from any pc on network
                              also i can scan to any pc on network.
                              tried to reinstall the driver but no good
                              i used UFR II and the pcl v.15 and v87 and the driver can not detect the printer
                              please help
                              thanks raouf
