Canon NP 6551
  • alan
    • Mar 2008
    • 40
    Canon NP 6551
    The LCD display of our machine turns dark,cannot read the messages..messages are very faint...have cleaned the connector,the ribbon wire..resolder connections..still same problem..even turning the display control clockwise and counterclockwise does not help...can i ask for any suggestions??THANKS..
  • Brian8506
    • 1658
    Replace the lcd display
    • THUK
      • Jul 2008
      • 195
      hi,what about replacing the power supply for the lcd panel.
      • Brian8506
        • 1658
        Sounds like you have power but no backlight. If you use a repair service like Nationwide, it may be cheaper to just get an entire panel. I had the same problem a few months back. Panel fixed it.
        • teckat
          • 16083
          Turn VR 911 to desired brightness located under control panel.
          • alan
            • Mar 2008
            • 40
            teckat there are two VRs located under the control panel,VR1 VR2 respectively...and these VRs are located in pcb FG5-5202..but not the VR 911 as you have mentioned..
