Conecting Imagepass H1 with iRC5185
  • Apach
    • 157
    Is it possible to connect Imagepass H1 on iRC5185 (not CLC) without replacing the PCB's and/or the SW?
    There is no stupid question, just stupid answer
  • teckat
    • 16083
    How was this machine first set up ??? = Copier only/ ? Printer/Copier with Multi-PDL KIT ?
    READ THIS 5185 INFO~~~~~~~~~~~~
    imagePass H1 Info TP08 144.pdf
    imagePass H1 Install.pdf
    iR5185 Service GU .pdf
    • charm5496
      • 2387
      if the machine has any license keys installed in it you will have to transfer them out or deactivate them. The only other thing you might run into is a firmware mismatch between the H1 and the machine. If one is higher and the other has not been updated recently then they are not going to talk the way they should.
      You can verify what is installed on the machine by going to counter check and device configuration. You will see PS and PCL listed if it has those kits installed.
