iR5570 - waste toner container
  • y_us1982
    • Jul 2025
    is there any other procedure after removing the waste toner? my ir5570 get the waste toner full, after i remove the waste toner, the sign wont disappear. unlike ir8500, after remove the waste toner, should enter the svce mode, but i couldn't find any function to clear in service mode on my ir5570.
  • D_L_P
    Self Employed
    • Oct 2009
    • 1196
    Empty it and clear the counter in
    Copier-> Counter-> Misc-> Waste-TNR
    • bolabali
      • Feb 2011
      • 22
      I got same thing with iR3300
      somebody told me Copier-> Counter-> Clear->MMI OK
      nothing changes..
      • teckat
        • 16083
        nothing changes..
        U don't clear MMI -for waste toner message on iR3300 SERIES
        Waste toner case full detection mechanism
        Remove the waste toner case, empty out & clean or replace case >
        >then turn off and then on the main power switch.
        Clean both inside and outside of area A of the waste toner case
        with alcohol.
        • teckat
          • 16083
          iR5570-6570
          SERVICE MODE:
          COPIER>COUNTER>MISC>WASTE-TNR
          waste toner counter; when its reading reaches '250,000', the machine will issue an alarm on the User screen.
          Dispose of the waste toner, and reset the error code.
          MEMO:
          The waste toner bottle can hold toner good for a maximum of 500,000 prints. The machine will indicate a waste toner bottle full alarm when the counter reading reaches '250,000'.
          • bolabali
            • Feb 2011
            • 22
            bingo!
            two thumbs up teckat
            thanks alot.
            • teckat
              • 16083
              • bolabali
                • Feb 2011
                • 22
                • JPP Océ
                  and dont forget if the spring inside the tube is stuck you going to have a error code E 13
                  • Dedy.P
                    • 67
                    thanks for the info Mr.teckat ...
