Canon ir3100 -
  • D_Ritter
    • May 2010
    • 16
    Canon ir3100 -
    Are you trained on this machine..
    when its copying can you hear a clicking noise coming from the right hand door?
    • charm5496
      • 2387
      Probably the fuser assembly has flat spots on it casuing the issue. Like skynet said you should hear a noise coming from the right hand door if this is the case. Running a sample on 11x17 sheet should give you a better a view if the line is occuring multiple times across the page.
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5015
        Print a PG-10 test and you can exactly figure out what is wrong.Use A3 or larger paper.
        • zoraldinho
          • Mar 2008
          • 5015
          A white line is definitely fixing assy.Other issue is probably ITB cleaner.
          • tinnyjay
            • Oct 2009
            • 663
            The white line is ITB cleaner problem.
            "Who loves the roses,must also bear thumbs"
            • charm5496
              • 2387
              cleaner issues go across the page not op to non-op like the line on the sample and would not give a blurred image.
              • tinnyjay
                • Oct 2009
                • 663
                Seems like attached or old toner on the transfer belt.
                • charm5496
                  • 2387
                  that line is typical of a fuser with flat spots on this wonderful unit. Canon has taken several good years off my life with this model.
                  • Peter Sim
                    • Sep 2008
                    • 445
                    I believe is fixing unit problem like what charm5496 had say.You can try to lose the pressure to comfirm and then tighten it againt back the to position.
                    • D_Ritter
                      • May 2010
                      • 16
                      Well guys, thank you all for your replies.
                      The ITB Unit was replaced some days ago, because of toner on the printouts.
                      When I replaced it, I saw the problem I described about.
                      I think the Fuser Unit is a good idea. Have just found an old ir3100 with the same problem. I looked at the fuser and saw the flat point.
                      So thank you everybody for your support.
                        Its a collection of crap bundled into one machine, having said that the doc feeders ok
                        • charm5496
                          • 2387
                          not a problem. Good luck with this problem child!
