Canon IR2200 light copies
  • copyman
    Owner / Technician
    • Sep 2005
    • 4765
    I don't know this model that well. Customer called and said copies are light all of a sudden. What will cause light copies in this model.
    Thanks for the help
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Depend how many copies do you have.
    1.drum?
    2.developer?
    3.scanner?
    4.transfer?
    • montana
      • Aug 2008
      • 392
      hi..is the internal printing the same?i would print a report and see if it is light printing so i have to check the developer-the corona-the drum-laser scanner-HV board
      i hope this help....good luck
      • Brian8506
        • 1666
        Have you been to the machine yet?
        • DAG COPIERS & COMPUTERS
          • Oct 2010
          • 860
          Yes, Brian is is right! First get to the machine and give it a trial, u may find it is something small like merely cleaning of the transfer roller etc. Make your own fault diagnosis through preliminary checks first, this will give a lead for others make a viable input to your effort.
