GP605 E100
  • jiongpao
    • May 2009
    • 413
    GP605 E100
    From the SM E100 appear related with scanner unit. My GP605 got a strange phenomena, it can keep running but after every 20-40 pages it will come out e100. After restart the machine u may continue using and if u lucky it can go through 60 pages before the code appear again hahahah .... I admit it almost antique with over 6mil copies
  • charm5496
    • 2387
    replacing the laser should take care of your issue with the E100 code. The intensity of the laser is probably getting weak causing your error codes.
    • mrfixit51
      Lead Service Technician
      • Oct 2008
      • 1975
      Bang on answer!
      The laser needs glasses ;-)
      • Canuck
        Tech Specialist
        • 1713
        Check the shutter linkage and clean the beam detect pcb sensor. Could be dying laser also.
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          That has been a common problem ever since this model was new.
          We once had an iR60 (printer only version of the iR600) that had the laser fail with this code with under 5k prints on it.
          • anothertech
            • 1771
            The mirror that deflects the beam to the Beam Detect SensorPCBcould be dirty. The only way to access this mirror is to remove the scanner assembly first and go through the cavity that the scanner filled. This mirror is not part of the scanner assy.
            • jiongpao
              • May 2009
              • 413
              Thanks i will try on those methods that ya guys suggested and will get feed back soon. But i can tell its 50/50 because few of that machines got this kind of problem and after change the laser unit everything find. i changed the image processor PCB, BD PCB and laser driver PCB theres no cure for e100
              • teckat
                • 16083
                no words needed'
                • D_L_P
                  Self Employed
                  • Oct 2009
                  • 1196
                  Originally posted by jiongpao
                  ...theres no cure for e100
                  Did you enter the values for the laser? I can't remember if you can see it by looking down in the optics or not. Look for a sticker with the LA-PWR-A, LA-PWR-B, IP delay or PVE-offset. If those values for the laser aren't correct you can get an intermittent E100. I'm with Charm, MrFixit, Canuk, and KenB, those laser assemblies went bad a lot. I can't recall ever seeing an E100 that wasn't cured by replacing the laser, or entering the correct values after another tech (me included) replaced the laser assy and forgot to enter those values.
