Hi all! We have a Canon ir1025if and a 3235i and are having problems with scanning to email. We switched our email hosting to gmail and I have been tinkering with the email/i-fax settings and nothing seems to work. Even called the place we bought them from but still haven't found a solution. I'm trying to get the 1025 working first since it is in my office (3235 is in another office 3 hrs. away). I have changed the ports to 993 for receiving and tried 465 and 587 for sending. Have even tried the ip of the smtp server. Any suggestions?
Switched email hosts - gmail not working!
Question :
How do I Use GMAIL as SMTP Server for Universal Send?
Answer :
Lately there have been lots of requests on our imageRUNNERS to use GMAIL as the SMTP Server. Here is the info from mail.google.com.
Configuring other mail clients
The Quick Answer
- Follow the instructions below to set up POP access in most POP clients.
- Google Apps users, please follow the default instructions unless otherwise noted, replacing 'your_domain.com' with your actual domain name.
We offer instructions for configuring some clients not in our supported client list. If you encounter difficulties, we suggest contacting your mail client's customer support department -- we're unable to provide assistance for clients not in our supported POP client list.
Non-supported clients:
While configuration instructions are available, we're currently unable to provide support for these clients.- Entourage 2004
Entourage X
Eudora 5.1 (and higher) (Light Mode)
Eudora 5.1 (and higher) (Sponsored & Paid Mode)
Eudora for Macs
Foxmail 5.0
Mozilla 1.7
Netscape Mail 4.5, 4.6, or 4.7
Netscape Mail 6.2
Netscape Mail 7.x
SnapperMail
The Bat! v3.62 Professional Edition
Thunderbird 0.x
- Enable POP in Gmail. Don't forget to click Save Changes when you're done.
- Configure your client to match the settings below: Incoming Mail (POP3) Server - requires SSL:pop.gmail.com
Use SSL: Yes
Port: 995 Outgoing Mail (SMTP) Server - requires TLS:smtp.gmail.com (use authentication)
Use Authentication: Yes
Use STARTTLS: Yes (some clients call this SSL)
Port: 465 or 587 Account Name: your full email address (including @gmail.com or @your_domain.com) Email Address: your email address (username@gmail.com or username@your_domain.com) Password: your Gmail password Unless you're using recent mode to download mail to multiple clients, make sure you've opted not to leave messages on the server. Your Gmail settings determine whether or not messages stay on the server, so this setting in your client won't affect how Gmail handles your mail.
Please note that if your client does not support SMTP authentication, you won't be able to send mail through your client using your Gmail address.
Also, if you're having trouble sending mail but you've confirmed that encyrption is active for SMTP in your mail client, try to configure your SMTP server on a different port: 465 or 587. - You're now ready to use POP with your Gmail address.
Accidents don't just happen. They must be carelessly planned.Comment
causes for an 801 communication error include:
- A timeout error occurred while the machine was communicating with the SMTP server to transmit an e-mail message, or transmit/receive an I-Fax, due to a problem with the server.
- The SMTP server returned an error message during the SMTP connection.
- The settings for the e-mail address are incorrect.
charm,
I used the info you gave me and tried ports 465 and 587 and now came up with error 0752. I attached a screenshot of the settings in Remote UI. Maybe I need to change something.
Uploaded with ImageShack.usComment
here is a link to help at Gmail - Outlook Express - Gmail Help
I think you have to manually change the SSL ports in service mode as well - copier>option>body>level 2Accidents don't just happen. They must be carelessly planned.Comment
Well I talked to the salesman that sold the units to me and he's been working with me on this issue for a while. Apparently Gmail has to authenticate using TLS and this printer does not support that. Is there any other free email providers similar to Gmail that do not require the authentication and work well with Canon copiers?Comment
click on link below
Free SMTP Server**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
You sort of have the answer - but it is SSL that the iR1025iF does not support and so will not work with gmail. Even though you can change the ports, you do not have an option to select SSL for your connection. I cannot answer why not - Canon just says nope and do not plan for it.
Actually it is an issue with a number of the newer units. Would seem like it would only be a problem for the old stuff but nooooo. Not a nice look on customers faces when the salesman told them "latest greatest" and then I get there to configure it and say "no SSL".
We keep a list of known public "relay" SMTP servers - but 1) some e-mail servers will not accept from relays, and 2) your e-mails can be read as they are not encrypted.Comment
jputra
Re: Switched email hosts - gmail not working!
Has anyone had success with GMAIL hosting & the 1025if yet?
(just curious as thread seems to have died)
Thanks in AdvanceComment
