Re: Switched email hosts - gmail not working!
The following are the Gmail SMTP server and port settings for sending emails through Gmail from any email client program:
http://techblissonline.com/troubleshoot-gmail-smtp-server-connection/
Gmail service providers require email clients (for example Outlook Express) to authenticate via SMTP port 465 with secure communication (SSL).
The issue is when the exact same configuration information is transferred from email clients to Canon devices, customers cannot send email. The result is error code #839.
The reason for this is Canon devices do not work when port 465 is used for SMTP transmission.
Port 587 has to be configured on the machine for send via e-mail to work.
To resolve the issue, SMTPTXPN option has to be changed in Service Mode level 2 to 587 and Canon devices must be configured to authenticate via SMTP with SSL enabled.
- Access Service Mode level 1 by pressing Additional Functions, - 2 and 8
- Access Service Mode Level 2 by pressing Additional Functions - Additional Functions - 2.
- Once you are in Service Mode level 2, select Copier > Option > Body > SMTPTXPN, enter 587
- Select OK and recycle the machine to apply the change.
After machine recycle, select Additional Functions > System Settings > Network Settings > Email/I-Fax.
- Depending on which service providers you have, enter smtp.att.yahoo.com or smtp.gmail.com for SMTP server
- Enter a valid user e-mail account for E-mail Address.
- Select Authent./Encryption > SMTP Authentication (SMTP AUTH) - On
- Set Allow SSL (SMTP Send) On.
- Select OK to apply the changes.
- Access Network Settings and make sure IP address, Gateway, DNS settings are correctly entered. (These information can be obtained by using a customer's networked PC nearby, access the command line, enter ipconfig /all.)
- Restart the Canon device and start sending e-mail once it is Idle.
- Under Outgoing mail, set Gmail SMTP server address as smtp.gmail.com.
- Configure Gmail SMTP user name as: your full Gmail address (including @gmail.com) Google
Apps users may have to enter username@your_domain.com.
- Configure Gmail SMTP password as: Your Gmail password.
- Configure Gmail SMTP port as: 465 or 587.
- Configure Gmail SMTP TLS/SSL required as: yes.
