Canon iR5570 - Scangear on Windows 7 x64?
  • peakbagger66
    • Aug 2025
    Has anyone gotten this to work? I've tried Scangear 2.21, even tried color scangear (which totally doesn't work, we expected that) but so far no love.
    I can install the application fine and I can discover the scanner but when I run a scanner app (Microsoft Office MOD) it does not see that the scanner is installed.
    Thanks!
  • doktor
    • 214
    Scan gear for W7 not exist,try send option.
    • peakbagger66
      Thanks, I was able to work up a solution involving XP Mode. It works like a charm!
      If anyone is interested I can put up a how-to.
      This should work for any other scanner/win7 issue as well.
      • kuby
        • Oct 2007
        • 1409
        Yea I am interested..shoot it my way.
        • peakbagger66
          Will do! This weekend most likely. My walkthroughs tend to be picture laden and verbose. :-)
          • CarterMarkham
            • May 2011
            • 15
            ScanGear 2.21 and Windows 7 x64
            I have been having the same problem getting ScanGear to work. I even downloaded a european version (2.30) but it doesnt work either. Can you tell me what you did to fix the problem?
            • Peter Sim
              • Sep 2008
              • 445
              Yes me too
              Thank you.
              • CarterMarkham
                • May 2011
                • 15
                I got it to work! I use the xp virtual pc and installed the print and scan drivers there. It works like a charm however the typical user is not going to like it.
