CLC1100 -1180 range
  • djzolla
    • 71
    CLC1100 -1180 range
    any1 had much experience on these beasts? i have for many a year.
    i seem to be getting a problem on alot of machines recently when i do the drum and devs. yellow seems to be picking up from somewhere and sits on the near edge of the drum. this obviously after a while will wear the drum on the near edge causing dev (yellow or 4 colour) to dump at front of machine.
    changing the drum and devs and/or yellow dev unit doesnt seem to crack it! the wierd thing is its only started to happen in the last 6 months or so.
    any1 else come accross this oddity? it always seems to be yellow!
    bearing in mind ive cleaned up around area, rewired both coronas, did grid....etc etc. so if its not the drum or devs or dev unit....hmmmm i have no idea...does any1 have an idea out there?:
  • copyguy5
    Canon Clc1180 Manuals
    THe manuals you were looking for can be downloaded from:
    Index of /protectedmembers/030114/CLC1180
    Good Luck
    COPYGUY5
    • djzolla
      • 71
      hmmm not really looking for a manual here chap....kinda hoping someone could help me out if theyve come accross it.....aint gonna find this fix in a manual unfortunately
